Bobbo
Aug 19, 2021Explorer II
Almost lost the microwave while driving.
I just towed my Airstream 2017 Flying Cloud 23FB 200 miles. I didn't hit particularly bad roads. I didn't hit any speed bumps.
When I set up, I found my microwave hanging halfway out of its enclosure.
After removing the faceplate and investigating, I found that Airstream put two, narrow, boards under the microwave legs for it to sit on, then screwed the faceplate to the microwave, and screwed the faceplate to the cabinet to hold it in.
This would have been fine, but they put the support boards too close together. There was less than 1/8 of an inch of the legs on one side of the microwave sitting on the support board. Over the last 4 years, it finally vibrated till the legs on one side fell off of the support board leaving only the faceplate supporting all the weight of the microwave on that side. The faceplate finally broke, releasing the microwave to shift around, and nearly fall out onto the floor.
I put the microwave on the bed to drive home, then put more support boards under it so it can't fall off of them. I have a new faceplate replacing the broken one. Nearly $65 with tax and shipping.
Ask me if I am happy with Airstream right now.
Following photos:
1. Left leg firmly on board, but right at left edge
2. Right leg barely touching right side of board. If I slide it left, the left leg will be off the board.
3. Supports I put outboard of the existing ones.
Following photos:
