So My Mod:
On this trailer awning, there are only the cheap plastic clips that hold the arms together while traveling.
![](http://i66.photobucket.com/albums/h260/Zeppe807/Camping/20150614_150527_zps3hg02uuy.jpg)
![](http://i66.photobucket.com/albums/h260/Zeppe807/Camping/20150614_150543_zpskgo6utdc.jpg)
And the problem that I have is that the upper end shakes a lot, the roll moves back and forth from the trailer, even with the knob tightened and the plastic clip engaged. This movement I think is what is causing the failure of the fabric at the track where the fabric slides in.
My previous trailer had a aluminum bracket, and a pin that held the two arms together. **This is not my original idea** SO while looking for the old model awning so I can maybe purchase the bracket to hold the Square Lock Pin in place. While searching I found where someone added a hose around the pin. I added the tubing to the pin and the wire, then bent the wire in a little more to hold it in place.
Take a look:
![](http://i66.photobucket.com/albums/h260/Zeppe807/Camping/20150614_150551_zpsq20rnm5s.jpg)
It fits Tight. I then move it up as far as I can reach.
![](http://i66.photobucket.com/albums/h260/Zeppe807/Camping/20150614_150610_zpsvtpy4ddr.jpg)
This holds the arms TIGHT! And it does not allow for the bars to move much. In fact, it now does not stress the fabric at all, so mission accomplished.
I hope this can help others too.
Happy Camping!
Joe
