Dadoffourgirls wrote:
kw/00 wrote:
dodge guy wrote:
I would stay far away from any small diesel. They are problematic and not worth the aggravation.
This coming from a diesel tech.
Why are they? What are you seeing being the issues with them?
Thanks
dodge guy is biased against GM. Will be interesting if he shares "facts" that can be confirmed. I admit, I am biased toward GM.
I own a couple of Kubota small diesels and the only issues that I had were a low pressure fuel pump and injectors failing, likely due to water in the fuel from lack of use by a previous owner. But then I haven't had much trouble with gas engines either and wouldn't mind trying a gas engine in either application.
As for the Cummins 5.0 in the Nissan, it was discontinued a year ago and there have been reports of poor dealer support even when it was still in production. Fuel economy with it was surprisingly poor and that probably killed it as much as anything.
I would say that the GM 3.0 is probably a good engine but little track record so far. With the increased tow ratings and increased availability I expect to see a lot more on the road.
Personally, right now I would go with the Ford 2.7 Ecoboost or the coming 3.5 hybrid. With fuel prices in my area either would be less expensive to operate and both engines have good track records. Actually, I would wait a year on the hybrid since I am not in a rush at this time.
