- Airstreamer67ExplorerI like to know my truck's fuel mileage, so use a Tuthill 13 gpm pump with an electronic fuel gauge. I fill the truck from a 91 gallon RDS auxiliary tank like I would at a filling station. I also use the system for a diesel tractor, RTV and generator. I have two fuel filers plumbed into the system to assure clean and waterless fuel.
- olddesertriderExplorerI use a simple kitchen cooking timer to time the aux tank pump on and off cycle. Do the initial main tank fill in your driveway at home to
get a baseline for timing your particular tank setup. Works like a charm and so very cheap!!!
olddesertrider - trucker495ExplorerThank you all for your reply.
Happy trails
Kyle - rodknockerExplorerI put one of these on my 60 gal RDS tank. Flows about 1 gpm, no complaints. Just used it on a 4863 mile road trip over Christmas. I turn it on for 15 minutes when main tank is at 1/4 mark. It will over flow if you don't turn it off.
Mr Gasket part #12D Advance Auto Parts - Miles_AwayExplorer
trucker495 wrote:
Miiles away do you happen to have a part/moden number for the pump? Oreilleys here in Tucson can't seem to help me
Kyle
I went on the O'Rielly web page and found one just like mine except it is only 6 volt, but I'm sure they have one just like it in 12 volt. It is an Airtex # E8011. They also have a Mr. Gasket #12S. Both are low pressure (5 to 8 lbs). They run about $50. (sorry about the under estimate on price). The filter I use is a WIX #32123 and it screws onto a base that you must mount next to the pump. That part number is WIX 24309. The reason I use a pump is that gravity feed will not flow through the filter. If you choose not to filter your AUX tank, then you will not need a pump. Good Luck! - GoPackGoExplorerTrucker495 -
Yes, I am very happy. It is simple and works perfectly every time ! Has an on/off petcock on the side of the tank which I normally keep closed while driving. In general, I turn it to 'on' at night after I get set up at camp.
It IS a very slow process to refill the OEM tank. I assume because it's a very small diameter line that connects the aux tank to the OEM filler hose. There is also a one-way valve at that junction which closes when the tank is full so fuel will not continue to flow and go out the fuel cap (or vent system).
That's why I just transfer the fuel overnight, although if I absolutely needed to I would not hesitate to flip open the petcock if I was running short of fuel in the OEM tank before I was done driving for the day - and I have done just that a few times.
I like simple and really have found no need for an electric pump.
Tim - trucker495ExplorerMiiles away do you happen to have a part/moden number for the pump? Oreilleys here in Tucson can't seem to help me
Kyle - Miles_AwayExplorerI have a gravity feed set up with a gate valve on the petcock coming out of the Axl' tank. Since I wanted to filter fuel between Axl' tank and main tank, I installed a WIX filter/water separator ($25), then installed a low pressure fuel pump from O'Rielly's Auto Parts for about $15. When I'm ready to transfer fuel, I open the valve and switch on the pump. My transfer rates is about one GPM.
- trucker495ExplorerThanks for the info. Are you happy with the gravity feed system?
Kyle - GoPackGoExplorerI found this one at Northern Tool.
http://www.northerntool.com/shop/tools/product_200609552_200609552
I bought my tank from RDS, but use the gravity method to transfer fuel. I looked on their website but did not see any pumps, but you might call them to see if they can give you some leads.
About Travel Trailer Group
44,026 PostsLatest Activity: Mar 01, 2025
