- I have an Edge Insight CTS2. I love it. The Insight is just a monitor, not a programmer.
Prior to the CTS2 I had a Insight CTS.
Prior to the Insight CTS I had a plain old Insight, which had an LCD display and only displayed 4 parameters at a time. Txsurfer wrote:
I see you can add the EGT sensor - how hard is that and what does it really tell you?
Drill a hole in the manifold.
And just like the name implies, it reads EGTs- DurbExplorer
Txsurfer wrote:
Does the Edge read the trany data off the port or do you have to add sensors? I see you can add the EGT sensor - how hard is that and what does it really tell you?
The transmission temperature is off the port. The EGT sensor was an easy install on a 5.9 as I had good access to the exhaust manifold. There are precautions that must be made when drilling and tapping to pick up all the metal chips and prevent them from making it into your turbo. Earlier trucks such as mine would deliver power and generate heat to the point of doing damage to the engine. The monitor will help you alter your driving habits to keep that from happening. - Cummins12V98Explorer IIIIf it's a 2010 or newer don't waste your money unless you are upping power. The computer will not let it hurt it's self.
- TxsurferExplorerDoes the Edge read the trany data off the port or do you have to add sensors? I see you can add the EGT sensor - how hard is that and what does it really tell you?
- jnharleyExplorerWe use an Edge for our 2015 Ram dually. We are satisfied with its performance.
- DurbExplorerI have an Edge CTS with suction cup window mount. It shows 5 usable functions you choose at once with your top 3 being oversized. I find it to be indispensable. Don't know about 08 and the 6.7 but exhaust gas temperatures were not available via the OBD port on my truck and required a separate sensor. The EGT is the function I monitor the most followed by coolant and trans temperatures. The CTS is easy to read and is appropriately lit for night driving.
- donn0128Explorer IIIf you have a smart phone, download Torque and buy yourself a 15 dollar OBDII dongle from one of the dozens of Ebay sellers. The Pro version gives you access to everything that the Mfg allowed access to via the OBD port.
About Travel Trailer Group
44,027 PostsLatest Activity: Apr 19, 2019
