- coolestdudeExplorerGood move Rob. Don't by someone else headache.Run don't walk away from this one.
Happy Trails! - rob_snell1017muExplorerThanks for the quick response to my issue. I appreciate your expertise and advise, so i am walking / running away from this one. You turned out to be my guardian angel, about 11,500 dollars worth! Kind regards, Rob
- coolbreeze01ExplorerI wouldn't buy it. Could get worse. I've seen some that were hideously ugly from delamination/water intrusion. Good luck.
- Mickeyfan0805Explorer
downtheroad wrote:
It's MORE than a major concern It's called de-lamination caused by water intrusion or glue failure. Either way, it will get worse and is a very expensive repair.
Look for a different trailer.
EXACTLY!! Delam is an extremely expensive repair and is usually something that spreads. Don't let yourself get excited by the concept of this trailer and make a mistake. There are plenty of options out there. - downtheroadExplorerIt's MORE than a major concern It's called de-lamination caused by water intrusion or glue failure. Either way, it will get worse and is a very expensive repair.
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 21, 2025
