MegaJohn's avatar
MegaJohn
Brake Controller Showing Short in the System
On the way home Sunday from our last outing our brake controller reads a short in the system. We made it home safely, but the brakes were in & out the whole way home.
I used my test light to check the brake wire to positive at the 7-pin connector and it would light. I'm not sure this is a good test though, as it may have only completed the circuit.
If I use my ohm meter, could I narrow my search to the truck or the camper? If it's in the camper, I expect I could then remove each drum's magnet from the circuit by cutting the wires leading to the drum to find which is having a problem.
I'd like to avoid having to pull each hub to check the wires inside... I just packed the bearings last spring. I could do it, just trying to avoid it if I can.
Now that I think about it... Could I disconnect the brake system's ground then test the brake wire to positive?
As you can see, I need assistance from others more experienced. Thanks in advance for your help!
Happy Camping!
John.
