- Cummins12V98Explorer III
RoyJ wrote:
If heavy towing, get semi metallics with the highest friction code (FF or better).
Take a look at F550 pads on Rockauto - only semi mets, no ceramic or organic. Same with medium duty trucks / school buses. Ceramics don't dissipate heat well.
Correct - RoyJExplorerIf heavy towing, get semi metallics with the highest friction code (FF or better).
Take a look at F550 pads on Rockauto - only semi mets, no ceramic or organic. Same with medium duty trucks / school buses. Ceramics don't dissipate heat well. - FlatBrokeExplorer II169,000 on my 03 GMC I bought new in 02. Never have replaced the original pads. Last service I had done said they were still good. Bet they don’t make them like that any more.
- Grit_dogNavigator
TECMike wrote:
Tried many other expensive pads and even slotted rotors, but I have found Motorcraft work best for my 2002 F-250 7.3 truck over the years.
OMG, how many sets of pads and rotors you gone through on that truck?? - TECMikeExplorerDone a lot of towing, sometimes in the Rocky Mountains and hot Texas heat.
My favorite pads are Ford Motorcraft Superduty Extreme Service pads. I replace rotors with Motorcraft rotors rather than having old rotors turned.
Tried many other expensive pads and even slotted rotors, but I have found Motorcraft work best for my 2002 F-250 7.3 truck over the years. - All four of my rotors are the original since new. 205,000 miles. Never even turned them. Slap the pads on and go.
- Garry_GayleExplorerThe Ford EB is not as good as the Cummins EB
- Cummins12V98Explorer IIIMust be a Ford thing as the last Ford truck I owned was a 69 F100 with drums.
Or it could be the EB does not hold back much and the service brakes are dependent on much more. - ferndaleflyerExplorer IIIAnd most of those after market rotors are from China--right now sitting in the container log jam in CA.
- Garry_GayleExplorerThe rotors on my 06 F150 and my 08F450 were both one and done and I measured them myself.
About Travel Trailer Group
44,027 PostsLatest Activity: Apr 19, 2019
