valhalla360 wrote:
mich800 wrote:
Groover wrote:
valhalla360 wrote:
Groover wrote:
$1,900 is a whole lot less than an inverter drive standalone generator of that capacity, if you can even find one. The closest Honda makes 2,000 less watts and costs $3k more.
Thanks for the info but I'm not sure where you are getting pricing.
A 2400w honda isn't $4900 (7500w is way overkill for a 30amp RV so not really relevant). Heck helped friends pick out a 3100w Champion last year for $550. That will handle pretty much anything a 1/2ton truck can pull. So far the only real advantage is you save some bed space.
Is the Ford system rated for peak or continuous load?
Also, Honda and every other generator manufacturer produces larger units that can put out 2000-2400w continuous.
If you are really worried about bed space and lugging it around, a simpler option is to add a generator platform to the A-frame on the trailer and bolt/lock it down.
If all you want is 2,000 watts, which is all that the Honda put out continuously, you can get that option on almost all of the 2021 F150's for $995. And that is less than the comparable Honda also. Plus, no fuel to mess with, it is always there and it is a lot harder to walk away with.
The only thing I would add it the Honda cannot put out 2000 watts continuously. I have tried, it cannot it will overload.
If the Ford rating, Peak or Continuous? If could easily be the same situation.
Also Honda and every other generator manufacturer puts out a wide variety of wattage rated generators.
Really if it's just keeping the bed clear and not having to lug it around, you can be a mount for the A-frame of the trailer that can be bolted/locked down with a cover.
From what I have been able to find out the Ford rating is for continuous output. On the other hand, the Honda EU2200 is rated for only 1800 watts continuously. I have not been able to find a 2400 watt Honda like vahalla360 mentioned.
Also, the EU2200 is rated for 3.2hrs at full output.
Here are the ratings for Ford duration:
"Say you want to park somewhere remote and use the truck to power that camper. The hybrid 2.4-kW system will run for 85 hours on a full tank of gas at maximum load of 2,400 watts. The 7.2-kW system will go for 32 hours under the same max load conditions. If you’re not using all of those 7,200 watts, the system will continue for much longer, the company said."
The Ford can be controlled through your phone and it can be used to power the camper while traveling. Both could add a lot of convenience.
