Feb-09-2019 05:27 PM
Feb-10-2019 09:12 AM
Feb-10-2019 09:03 AM
Ride S40T wrote:
You're going to hear varying degrees of good advice on RV forums and A LOT of solid recommendations based on years of experience.
After considering any or everything read here, please please go out to one of the reputable sites like Shereline and run all the TV and TT specs. Find a worksheet that uses all the specs all the way down to the wheelbase, do not use a simple "pulling capacity" worksheet produced by TV manufacturers.
"Can" you haul something that big behind a 1500 (any make)? Sure. Will it be unsafe or kill the truck? Possibly. Run the numbers, even those wheelbase specs are important. Let the science behind towing be your first guide. Then decide on a TT within those parameters.
Lastly, please know dry weight & tongue weight issued by TT mfgrs can be a little optimistic on the low side. We used a tongue scale to find out our hitch weight is about 100lbs more than advertised.
Feb-10-2019 08:09 AM
Feb-10-2019 08:07 AM
MarkRBD2019 wrote:
More Info, the payload capacity of the truck is 1750 LBS and the towing 10460 LBS
Feb-10-2019 08:02 AM
Feb-10-2019 07:58 AM
Feb-10-2019 07:45 AM
Feb-10-2019 07:35 AM
MarkRBD2019 wrote:
I need to check the payload of my Ram but it sounds like this idea is going down like the Titanic. Sounds like I need a lot less TT or a lot more truck.
Feb-10-2019 06:30 AM
Feb-10-2019 05:56 AM
Feb-10-2019 05:52 AM
Feb-10-2019 05:47 AM
Feb-10-2019 05:26 AM
Feb-10-2019 03:07 AM
Feb-10-2019 02:24 AM
