May-28-2015 06:02 PM
May-30-2015 03:35 PM
Super_Dave wrote:
Tim,
What kind of footings did you need for the pole barn? I've been fighting with metal carport companies trying to get something similar built. I hadn't thought about a pole barn solution. Thanks for the idea.
May-30-2015 01:51 PM
May-30-2015 10:57 AM
JimK-NY wrote:
Nice but I do not understand why you need to put your camper in a building. Mine is weatherproof and built to be outside. Instead I would use the space for a workshop or other purposes.
May-30-2015 04:19 AM
JimK-NY wrote:
Dicor and Geocel Proflex last for many years.
May-29-2015 08:41 PM
Living in NY you should understand how freeze/thaw cycles damage joints. A small crack in the sealant of a joint can have water intrusion. That water freezes and expands the crack. The water thaws and the now larger crack refills. The water freezes and the crack gets even larger...
Likewise UV exposure from the summer sun degrades many surfaces, from that joint sealant to the EPDM roof.
To timdan94: Nice! Is a concrete floor in the plans or do you plan to stay with the stone floor?
May-29-2015 07:49 PM
May-29-2015 04:50 PM
fredandkathy wrote:
I built the same size about 8 years ago when I got tired of paying storage fees for the winters. I wish I had built it a bit bigger. I have my MH, boat, 2 farm tractors and a log splitter. It has gotten quite full. I also put 100 amp electric service in it so that I can precool the fridge befor a trip. I think that keeping the MH inside is easier on the roof and tires since I plan to keep this wone for the long haul.
May-29-2015 04:48 PM
Wagonqueen Truckster wrote:
That is awesome. I just bought 5 acres of land and want to put one if these up for my old TC. Since there us no foundation is a building permit required? Approx how much was this? Did you buy a kit?
May-29-2015 05:52 AM
May-29-2015 04:53 AM
May-29-2015 04:05 AM
May-29-2015 03:58 AM
May-29-2015 03:07 AM
May-29-2015 02:45 AM
