- msiminoffExplorer II
joebedford wrote:
Can you use your unit with the slide in?
My Alpenlite is 100% useable with the slideout in, although it does reduce the width at the entry door a bit.
If we're just making a quick stop for lunch or a potty-break then we don't bother to extend the slide... also if overnight temps are much below freezing then we sometimes sleep with the slide in.
Cheers
-Mark
- pjay9Explorer
Surf Ram wrote:
pjay9 wrote:
Surf...you got a flat-head in the woody?
It did when I owned it, the current owner has a Ford 302 in it now. I now have a Morris Minor Traveller Woodie, I should update my pic sometime...
Nearly brought one of those home when I was in the UK with the USAF in 70's...You got to post pic! So cool! Sometimes I wish I had my Vespa back '64 GL...opps! Have we hijacked this post...SOOORRRYYY folks!
Slides...oh yeah!!! They give you loads more room and sometimes are a PIA!!!! Warm regards, PJ :W - Surf_RamExplorer
It did when I owned it, the current owner has a Ford 302 in it now. I now have a Morris Minor Traveller Woodie, I should update my pic sometime... - jimh406Explorer IIII have to barely open the slide to get in. Once in, my camper is usable with slides in. It stays warmer with slides closed.
- clearyExplorerOur oversized U-shaped dinette that is in our full length slide along with the reefer completely blocks the door when closed. The slide narrows where the fridge is and allows the bathroom to be deeper. We don't consider this to be an inconvenience and is well worth the 7 second wait for the slide to go from fully closed to fully open.
Chuck
- pjay9ExplorerSurf...you got a flat-head in the woody?
- Surf_RamExplorerSummerwind 811S I can, a little tight though as I am 6'5" and 270
- pjay9Explorerkerry4951, good idea!
- kerry4951ExplorerYes on my AF 1140. I even installed a second slide out switch near the cabover. Once we climb into bed I can easily hit the button and bring the slide out in if its cold outside or if I want to be more stealth.
- BoatycallExplorer
Herb36 wrote:
1181 Impossible to get in or move in the camper
X2 for my Eagle Cap double slide... can't even get in the door. But I have yet to be somewhere where that's caused an issue.
About Travel Trailer Group
44,056 PostsLatest Activity: Jan 01, 2026
