Gjac
Sep 27, 2019Explorer III
Chassis strength of 20 -26 ft trailers with one slide
I have been looking at small TT's with one slide and was wondering what would be the difference in the chassis(frame) construction of the various models. I was not able to see much info on the frame construction, I beam vs box vs c section or the thickness of the steel. I see axle ratings of 3500 lbs or 4000 lbs each on some. I am assuming if the axle rating is 3500 lbs each that as long as GVWR of the trailer is less than 7000 lbs fully loaded every thing should be good. So my question, is the chassis construction pretty much the same or are some more robust than others? The ones that I saw that looked good from just the web sites were the ORV Creekside 18RBS 23 ft with 78 gals of FW. Coachmen Apex Nano 208BHS 25 ft 50 gals of FW. Coachmen 192 RBS 22ft 49 gals of FW. Hemisphere HyperLyte 23RB 26 ft 52 gals of FW. I never go to FHU CG's so FW is important to me.
