- _tiredTeacherExplorer II
jimw606 wrote:
When I had a Fifth wheel, I ran a wire out through the Mouse hole.Male plug on the end I pulled outside.
Did that on my Sunline. Don't have any mouse hole on this trailer. It has a marine-style connector.
Teach - jimw606ExplorerWhen I had a Fifth wheel, I ran a wire out through the Mouse hole.Male plug on the end I pulled outside. The other end was attached to a 110v wall plug I installed. Heavy extension cord to the 20 amp plug on the box.
I usually ran a heater off of this one, but have used 2 heaters, with one on the 30 amp circuit. - _tiredTeacherExplorer II
dave17352 wrote:
Just got back from Home Despot and switched out the single plug outlet (for the water heater) in the service bay with a dual plug. Now I can plug in a trouble light and hang it near the water filter and shut the bay door.
Put a 60 watt light bulb by the them no worries
It probably won't get cold enough for long enough to be a problem, but this will give my DW peace of mind.
Now, to hijack my own thread - has anyone run an extension cord into his trailer by slipping it past the slide seals? My Sunline's power cord stored under the sofa so i was able to run an extension out through the power cord's mouse hole. I have no other way now to get a cord inside other than through an outside gear door, under a dinette seat and out the inside access door. That would be a big air leak.
Teach - dadmomhExplorerDitto on the light bulb. We used that in the bilge of our boat until it was lifted out of the water for the winter. Never had a problem. Definitely remember to disconnect the water hose before retiring for the night and open the cabinet doors under the kitchen sink and bathroom vanity. You should be fine. Enjoy!
- wmosesExplorer
'tiredTeacher wrote:
We're camping for New Year's and my new TT has an on-board water filter, housed in a outside storage compartment, along with the water pump and HW heater. Is this filter in danger of freezing if the temps are mid-40s over upper 20s?
My RV has the same setup as yours. We have camped in temperatures just below freezing for a few hours so far and there was no problem. I typically disconnect the FW hose when I know it is expected to be lower than freezing overnight and use the on board FW tank.
As others have suggested you will want to consider heating that storage compartment. I have a small electric heater that l intend to use on its lowest setting but the (quiet) light bulb solution also is a good one, especially since the compartment is just below my bed. Going camping when the weather is in the 20's might be a tall order, though. - dave17352ExplorerPut a 60 watt light bulb by the them no worries
- Racine96ExplorerYou should be fine as long as the temperature goes up during the day to 40s. I would be more concerned about how unpleasant might be camping when in gets too cold. These TT are not meant for cold weather. My 2 cents.
- ScottGNomadThe temps would have to be 32 or below to freeze - and for some time at that. Can you just put a light bulb next to the housing? That would keep it from freezing.
- Dick_BExplorerYou can let the water drip a little if it gets down below freezing...
About Travel Trailer Group
44,026 PostsLatest Activity: Mar 01, 2025
