- CavemanCharlieExplorer III
travelnutz wrote:
CavemanCharlie,
So wrong! Drain fields usually have 8" to 12" of dirt over them. I have 2 of them here, another at our place up north in Michigan, and had one in Florida near WPB. NONE have even as much as 12" of dirt over the stones. My brother in Jupiter Florida just west of I-95 also has one at his very expensive home with 1-3/4 acres of fenced in property they had built 13 years ago. No way could you have the drain field any deeper as it would be flooded because the water table is so high. Actually, the dirt was added on top of his drain field as the top of it was level with the surrounding ground before the dirt was spread on top of it. The water table is so high in most of South Florida that you cannot drain the water out of an in ground pool because the pool will pop out of the ground from the very high water table. The sealed pool becomes a boat hull and floats! You in Minnesota do not have this problem.
BTW, just how far down in the ground do you think the top of your septic tank is if you have one. All of ours are 3" to 4" under the surface as I've scrapped the dirt off to get to the approx 2' X 2' lid and had them pumped when needed or every 5-8 years. Just 2 of us living in the places as we are long retired, like 17 years now. If more people are living there and adding sewage means more often having it pumped out.
You could be right about the Drain Field. I don't have one. I know where my septic tank is and yes, the lid is only a few inches down. The top of the tank is a couple of feet down. But, it's 6-7 feet tall ! I know this because I had to run a new water line to the house and the line runs under the corner of the septic tank. I have pumped my tank once. Was about 25 years ago. We have pumped my brothers a couple of times over the decades. They are not full to the top you know. The liquid drain is down a few feet on the side of them. - crosscheckExplorer IIHad one for 6 years in a TC. Just sold it a few months ago. Wanted to try it as in the many years of camping, had never had one in the 3 previous TC,s.
Our RV lifestyle is almost 100% dry/ boondock camping. Maybe 25% of the nights were spent in campgrounds that had dump stations.
Swapped the black water tank for more storage which is at a premium in a TC. Because of the small size of the cassette potable holding tank, (5 G), it encouraged us to conserve water which is one of the things which limits most people when they boondock.
As has already been stated, the tank can be emptied in any pit, or regular toilet plus dump station in about 15 seconds. No waiting in line ups. Using the toilet is no different than a regular one with a knife or ball valve.
If we were staying for extended time in one area, we would drop the TC and use the truck for transport to explore or travel to trail heads etc. Many times we would take the full or partially full tank with us and empty it into the many facilities that were in the area.
The cassette toilet helped us achieve our goal of being able to stay out longer in boondock situations.
Dave - travelnutzExplorer IICavemanCharlie,
BTW, just how far down in the ground do you think the top of your septic tank is if you have one. All of ours are 3" to 4" under the surface as I've scrapped the dirt off to get to the approx 2' X 2' lid and had them pumped when needed or every 5-8 years. Just 2 of us living in the places as we are long retired, like 17 years now. If more people are living there and adding sewage means more often having it pumped out. - CavemanCharlieExplorer III
travelnutz wrote:
Mike Up,
And just where do you think the septic tank flow goes when it flows out as new sewage comes in? The drainfield only about a foot under the ground surface of course.
Septic tanks don't just hold the waste until it gets to the drain field. They begin the break down process on the solids. Also the drain field is more then a foot underground. And it is specially designed using the right types of soils to continue the process. - CavemanCharlieExplorer IIIIn MN you would get in big trouble if you dump human waste on the ground or into a hole.
- Mike_UpExplorer
travelnutz wrote:
Mike Up,
Just a very quick 15 second search turned up this link. One of many!
http://www.trailspace.com/articles/backcountry-waste-disposal.html
Start with section: First, a word about number one and continue as it's well explained. Many states recognize this proceedure for personal human waste disposal including Michigan where my sister's son was a ranger for many years as I'd said. Does't mean dumping your RV holding tank in as it's for personal human waste disposal. Yes, some states have different laws and regulations and it's up to you to know the laws of the state you going to dump your small portable toilet in. Want more links? do your own research as you obviously have a computer etc connected to the Internet or your wouldn't be reading or posting on the rv.net forum!
Seems you are the one who's nuts!
As I thought, you can't provide a link to each state's website, stating that those states allow this disgusting craziness.
You've proven our point. - travelnutzExplorer IIMike Up,
Seems you are the one who's nuts! - Mike_UpExplorer
travelnutz wrote:
westend,
As usual your fingers are poking keys without your brain engaged.
Just where do you think dispersed tent campers or campers on back country National Parks, State Parks, National Forests, State forests, BLM land, etc are going to HAVE to deposit their HUMAN waste excreta? Tell me boy!
Yup according to your cherry picked blabber, distance hikers far out back or even half way up a mountain tent campers or at the top of a mountain, and/or RV's with portable toilets that are totally full and are 50+ miles from any so called waste water plant or approved on site waste water system must not empty them or excrete any human waste at all, or if they must as nature dictates beyond a persons control, must they bag or container it and carry it with them until they get to a so called approved waste water location? Are you even awake or conscious?
Dumping in and approved toilet or septic system is exactly what I had said but NOT always possible! Bad news for your is that in a time of actual need, the digging of a hole per the rules in a remote location on public land away from human activity in the USA and reburying it properly and replacing the top soil layer is regarded as legal and an APPROVED method of disposal of human waste excreta. Go ask and Park Ranger (WE HAVE!) about it as you simply do NOT even have a clue! Try getting smart and away from your keyboard sometime, maybe you too will learn!
Of course, you cannot do it in a confined national monument or daytime small confined location as it refers to camping locations only, and that is obvious to those with a functioning brain.
As for waste oil from any of my vehicles or boats etc, I have no info as to where they dispose of the used oil when they change my engine oil. Don't play mister protective environment director when you don't even have a clue!
BTW, where does petroleum even come from? The sky? The water in the oceans? Lakes? Septic Tanks, An approved waste water plant, The moon? or last resort - from IN the ground? DUH!
You're nuts, provide a link to Indiana and other surrounding, populous states. - BumpyroadExplorercan't we all just get along?
bumpy - travelnutzExplorer IIwestend,
About Travel Trailer Group
44,056 PostsLatest Activity: Jan 12, 2020
