revmikeh's avatar
revmikeh
Decal Removal & Painting Aluminum on Fleetwood Prowler
I'm new to RV.Net and although I'm sure this has been covered many times before, I've been unable to find older posts covering this topic. Can anyone give me some tips to help me both remove the original Prowler decal from the front of my trailer as well as knowing how to repaint that area and several others that have faded? Most of the camper is in good shape (paint-wise)but there are a couple of areas I'd like to touch up. What kind of aluminum (etching?) primer and what paint is best? Thanks for your time.
  • My 2000 Prowler has terrible paint and decals. As a capable do-it-yourselfer I decided to start by repainting just the front end using spray cans.
    I used a heat gun to remove the decal. It was sun damaged and came off in small pieces.
    I stripped it down to the bare aluminum and carefully applied Rustoleum per the directions. Looked great for a few months then started to peel. Did it again using a different self-etching aluminum primer and different paint. A year later it's peeling again. I've painted some of the worst bare spots with Krylon 'Fusion' and so far so good. I figured if Krylon sticks to plastic maybe it'll stick to aluminum.
  • I attended the FMCA Rally in Indio last January. I looked at examples of paint quality and got estimates from four vendors.
    I just had the decals removed and a partial body paint (covering all shadows of decals) on my RV. Work was done by Collision Clinic in Palm Desert, Removing decals was a problem as they come in different mil thicknesses and can not all be pulled off, especially if fractured by the suns rays. To remove the difficult decals they used a special tool just for that purpose. It looked like a stack of silicone pancakes placed on a rod and put on a drill. It quickly removed the decals without damage to the fiberglass surface. Painting is an Art and not all paint is the same. I recommend a professional painter who guarantees his work and products.
  • Time and Patience are required to do a good job .
    Pick a hot day .
    Use the hair dryer or heat gun .
    Peel very slowly .
    Figure a half day to remove them all .
    Your option , there are lots of colored swooshes and other designs available online to install after you have taken the brand name stuff off .
    You can often match the decal on your tow rig to your trailer .
    If you spend a month at Palm Springs and hit the RV shows in the winter there are several vendors who have a display .
    The swooshes I had applied in 2004? show no deterioration or peeling .
    I paid to have a pro do the install .
    The removal better fit my skill level .
    Besides what else am I gonna do while hanging out at the RV Resort ?
  • Cant help with the painting part but using a heat gun about 8~10" away from the decal will make it lift easily and leave no residue behind.
