DannerFamily
Nov 25, 2008Explorer
Ace! wrote:
I think a loss of power occurs more at altitude than anything else. Proper gearing though, and towing in the right rpm range for what the engine was designed seems to keep my truck from pinging/knocking. I use 87 octane only and have never had a problem with pinging/knocking. My current truck has the 3-valve V10 with increase hp and torque over the earlier models, so it might depend on the year of truck, I don't know.
Don't be offended - the diesels do pull better. For us this summer Eisenhower pass with 9500 lbs in tow - cruise control set at 70. Allllll the way up - with more power on tap, locked torque converter (4th gear) and cool trans/engine temps. SWEEEEEETTTTT!!! Only problem I had was a damn Prius that got in the way (couldn't do better than 65). Massive torque means i can maneuver my trailer into campsites (even uphill) in idle. Gassers you have to goose to move.
Diesel are the best option - period.
44,056 PostsLatest Activity: Jan 12, 2020
