mdprowash's avatar
mdprowash
digital volt meter
Can I disconnect the wires for the battery on the back of the fresh/black/grey/battery meter in the camper and install this digital meter instead?
https://www.amazon.com/DROK-DC2-5-30V-Waterproof-Voltmeter-Monitoring/dp/B00CK3P20S/ref=sr_1_2?ie=UTF8&qid=1466989430&sr=8-2&keywords=digital+battery+monitor+12v
  • Depending on your monitor panel, you may be able to connect to the wires for the existing battery meter portion. That's what I did and mounted a small cigarette lighter sized digital voltmeter that reads when the monitor panel switch is pressed. No extra push-to-read switch was required.
  • I doubt you could disconnect without killing the tank level indicators, I would just tie on to the 12 volt line going to that panel.
  • Suggest you put a momentary push on switch in line with it so you dont create another parasitic draw while it is in storage.
  • How would you mount it on the tank display panel?
    I've mounted similar ones by using a standard single gang blank outlet box cover plate and cutting a square hole using a utility knife (drill a few holes to get the cuts started). A nylon cover plate is softer and easier to cut a hole in it. Then you can just screw the plate directly to a wall - you don't need a box behind it because it's low voltage.
    You could mount the meter anywhere as long as you have unswitched 12 VDC nearby. The wires to those holding tank/battery displays are pretty tiny gauge and perhaps could result in lower voltage than you actually have at the converter panel.
  • I'd like to mount it in the same vicinity. Thought maybe I could use existing wires or tap in?
  • Where do you want to mount it?
    Why disconnect....you can just add the new voltmeter.
