4aSong
Sep 24, 2014Explorer
DLS-45/IQ4 Power Supply / Charger
I have an IOTA DLS-45amp with IQ4 smart charger Power Supply/Charger sitting in my workshop and need input on what it can be used for.
Any suggestions would be greatly appreciated, It is roughly 3 or 4 years old and works flawlessly. I had upgraded our previous TT and prior to selling it I swapped it out with the original unit.
DLS-45 - 45 AMP POWER SUPPLY/CHARGER
INPUT VOLTAGE 108-132 VAC
INPUT FREQUENCY 50-60 Hz
OUTPUT VOLTAGE 13.4 VDC
OUTPUT AMPERAGE 45 Amps
DESCRIPTION
The DLS-45 Power Converter/Battery Charger from IOTA Engineering converts nominal 108-132 AC voltage to 13.4 DC voltage for both DC load operation and 12V battery charging.
As a power supply, the unit's tightly controlled regulation allows the user to operate a nominal 12VDC load up to 45 amps.
As a battery charger, the unit will maintain the battery, delivering its full-rated current when the battery capacity falls sufficiently low. The voltage is set to deliver its maximum current for the necessary period of time to minimize undue stress to the battery caused by heating of its cells. This helps to ensure the longest possible life of the battery. Over time, as the battery nears its full capacity, the DLS-45 will automatically drop the current, providing a float-charge to the battery to prevent self-discharge of the cells.
MODELS
DLS-45
The DLS-45 provides AC/DC conversion up to 45 amps and features a Dual Voltage Jack, allowing the user to manually select between 13.6V and 14.2V charging.
DLS-45/IQ4
The DLS-45/IQ4 features an internal IQ Smart Charge Controller which automatically provides three-stage battery charging for safer charging and longer life for your system's battery.
SPECIFICATIONS
DC Output Voltage (No Load) approx. 13.6V (DC)
Output Voltage Tolerance (No Load) + or - .7%
Output Amperage, Max Continuous 45 Amps
Output Voltage (Full Load) approx. >13.4V (DC)
Maximum Power Output, Continuous 600 Watts
Ripple and Noise <50 mV rms
Input Voltage Range 108-132V (AC)
Input Voltage Frequency 47-63
Maximum AC Current @ 108VAC 11 Amps
Typical Efficiency >80%
Max Inrush Current, Single Cycle 40 Amps
Short Circuit Protection Yes
Overload Protection >100%
Line Regulation 100 mV rms
Load Regulation <1.5%
Fan Control Proportional
Thermal Protection YES
Working Temperature Range 0-40C
Storage Temperature -20 to 80C
Withstand Voltage 1240V @ leads
Dimensions 9.7" x 6.7" x 3.4"
Weight 5.0 lbs
DESCRIPTION
MODELS
DLS-45
DLS-45/IQ4
SPECIFICATIONS
Weight 5.0 lbs
