Do you need a slider hitch with a 61/2 ft bed
rtaylor0830
I am thinking of upgrading trucks right now I have a 8 ft bed with a 16.5 k hidden hitch. Will this work in a shortbed f250 making tight turns.
19 REPLIES 19
pyoung47
Yes
romore
We managed to punch out the cab window with our first fiver, we have a slider but it is impossible to move with the trailer attached. The current unit misses the cab but not by much.
You need to measure the distance from the center of the pin to the edge of the trailer (dimension A) Now measure from the center of said pin to the rearmost portion of the cab (dimension B), if A equals or exceeds B you need a slider or be very very careful.
therink
I have never needed to use my slider in 4 years of pulling fivers.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
kw_00
Not really, depending on fifth wheel. I have never had a problem with mine.
A truck, a camper, a few toys, but most importantly a wonderful family.
is_it_friday_ye
Depends on the trailer a bit. I have a Reese slider on my short bed Dodge and never use it. It would hit the rear window if I made it go 90 degrees though. Our trailer has cut outs on the front cap corners which helps a bit I believe.
2007 Dodge Ram 3500 Cummins SRW, Airlift airbags, Bilstein shocks, Smarty Jr., stainless turbo back exhaust, B&W Patriot 18K
2015 Grand Design Momentum 328M, disc brakes, Progressive Industries 50 amp EMS
