Electric Trolling Motor Battery Charging
Oldtymeflyr
I am trying to figure out the best way to charge a 12v battery that I use to power an electric trolling motor.
Our main boat engine's electrical system does not have the capacity to charge the trolling motor battery.
Our TC has 180 watts of solar panels, approximately 17 volts, going to a Samlex a PWM controller rated at 30 amps charging two batteries. Right now the TC has two 12 volt batteries, but I can switch in two 6 volt batteries.
We do not have an inverter. Our current solar system works well and we have all the capacity we need.
We are usually off the grid, boondocking, when using the boat.
Naturally we need to charge the battery in the evening or at night.
I have thought about getting an inverter to run a battery charger and let it be at that. I have also thought about just rotating the 12 volt trolling motor battery into the camper battery bank and see how that goes, a little inconvenient.
Any comments or suggestions?
Rick
12 REPLIES 12
tonymull
I have two 90AH batteries that I use for trolling. I switch each day and put the partially discharged one on the solar panels while I fish with the fresh one. I have 200W of portable solar panels but you can make yours work if you are getting enough sun on them. I get 7.5-8 amps/hour in full sun but I'm in the north woods and dealing with sun that is less direct than down south. Still it works very well for me. A normal day of fishing for me leaves me at about 60-70AH so I need only recharge 25-35 and the panels do that easily.
Oldtymeflyr
Thanks for the comments.
Outboard motors just do not produce that much surplus electrical energy. Our 30hp Honda has a total of 10 amps. We may run it for half an hour a day fishing and that's it. If it was EFI a lot of that 10 amps would go to the EFI system. I don't troll with the 30 hp because it will make oil. With a load it works just fine.
I am going to look at the RC charger a little closer and see if it that will do the trick. I like this because it may be the simplest in the end, just one more not two more batteries.
I will also consider a couple of smaller 12v batteries, one on the solar charger and using one. Our batteries in the camper are generally fully charged in an one to two hours, so there is usually plenty of time for charging the second trolling motor battery.
Thanks, I will follow up with a report, probably in October at the latest.
Rick
mkirsch
Nomad II
Nomad II
Per the OP:
Take a look at RC Airplane chargers like I recommended above. There are a lot of them out there these days that can do lead acid batteries.
TxGearhead
^^^This. Some hard core fishermen do this to keep their troll motor batteries up.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
EricCO
Another option would be to put a battery isolator in your boat: https://en.wikipedia.org/wiki/Battery_isolator
When your cranking battery is fully charged by the motor's alternator, it will automatically start dumping extra current into your trolling motor battery.
Using the trolling motor won't drain the cranking battery with the isolator between them.
2002 Ford F-350 CC LB PSD 2007 Travel Lite 960rx Ultra 2018 Keystone Cougar 29BHS
mkirsch
Nomad II
Nomad II
Look to the world of radio-controlled airplanes for the solution!
Something like this, for example:
http://www.hobbyking.com/hobbyking/store/__64345__Turnigy_Accucel_6_80W_10A_Balancer_Charger_LiHV_Capable.html
It is 12V powered and capable of charging a 12V lead acid battery at up to 10Amps.
It is much more efficient than the inverter method.
Bob__B
Maybe a small quiet generator to sit by the boat to charge the batteries.
2007 Lance 1181, 2013 Chevy 3500 DRW
bcbouy
use an inverter,plug your battery charger into it and charge the battery.i have a 1000 watt i plug into my winch connector with an anderson,sort of.it's actually a warn quick connect.i've been doing it this way for years.total cost is under 200 bucks.and a couple bucks in gas.
2012 ram 2500 hemi crew cab sb 4x4 2015 northstar 850 sc 14.5 g3 guide custom fly fishing boat
RickW
with the info given,
1. you only have solar when boondocking, so charging must occur during the middle of the day.
2. you are using the trolling battery in the boat during the day.
Best is to swap two batteries and charge one every day. Either swap one of the TC batteries, or have two trolling batteries.
An alternative is to use an inverter and battery charger to charge the trolling battery at night from the two TC batteries. Doeable but inefficient due to 2 power conversions, DC to AC and AC to DC.
Another is to connect the trolling battery in parallel with TC batteries at night. They would equalize at about 2/3 of full charge each minus nighttime use. May not be enough for trolling.
Rick
04 GMC 1500 4X4X4, 04 Sunlite SB
hedge
sounds like you need Solar panels on the boat lol.
Maybe a second trolling battery that you could swap out, always having one being charged back at camp via solar, maybe with a 2 position battery switch to target it once your house batteries are charged. Probably would be much easier with a charge port.
http://mellomikeadventures.us/2016/07/feature-in-the-spotlight-palominos-battery-charge-station/
2017 F350 Platinum DRW
2013 Adventurer 89RB
time2roll
I would make some quick connect cables and swap batteries every day.
Anderson connectors would work great. Connector on the boat also.
jimh406
Don't use the inverter. Connect the battery to your other batteries when you need a charge. I'm sure others might have another idea.
