maria_bettina's avatar
Jun 20, 2022
Electrical Help pls
Hi! I bought a 250 Watt Electric Heater to stave off the chill at night (the tag says it uses 2.1A). We have solar panels to charge our 200A battery (I don't think that matters, but just in case).
Before the trip, I plugged the 250 Watt Heater into the 300 Watt inverter, and the inverter is plugged into the cigarette lighter in the camper. (The wire that runs from the cigarette lighter to the battery sized for 10A.) It worked fine. But now that my son and husband are on their trip, when they plug in the heater, the 10A fuse blows that is at the cigarette lighter. Twice.
They are able to play a DVD and TV by plugging it into the inverter. So everything works for the DVD and TV.
Nothing else is being charged or used on that inverter, nor at the cigarette lighter.
Note: There is an electric fridge/cooler, and it's being powered by the same auxiliary battery, but it's not on the same fuse (if that makes sense; I know I am not using the correct terminology).
My hubby just got to a campsite that has a power supply, and the heater works fine. So at least he is able to use it now without blowing fuses.
Any suggestions as to where we can start looking for the issue(s)?
TIA.
