What does your owner's manual say?
For my Duramax, the manual says I don't need the engine brake until I'm towing above 15,000 pounds. You may not even need it with the light-weight trailer you're towing.
When I tow my 19,000 pound trailer, the engine brake is always on. Once you turn it on just drive normally and it'll do what it has to do. Make sure your transmission is in manual when going down a mountain grade. Let your lower gears help keep your speed down. Your wheel brakes are not supposed to do all of the work, or even most of the work. Downshift the tranny and use the engine brake to keep your speed down; your wheel brakes are secondary braking items. Like I said before, your truck may not even know your trailer is back there.
