โMay-21-2017 07:57 PM
โMay-22-2017 09:46 AM
wnjj wrote:DutchmenSport wrote:
You're confusing "grade braking" with an exhaust brake. ...
โMay-22-2017 09:18 AM
โMay-22-2017 08:43 AM
Exhaust brake will do the same thing as manually putting your truck in a lower gear when coming down hill. It will hold your truck in whatever gear you are in and not allow an upshift to a higher gear, thus allowing the truck to move even faster. With exahaust brake, the engine will rev, it can get pretty high and sometimes can become a bit daunting, but that's what's it's suppose to do. When the engine reves that high, then you press the brake pedal and slow the entire rig down, sometimes, even enough to drop into the next lower gear. But normally, it will just rev the engine maybe 1000 - 2000 rpms higher than normal running.
The thing it does is keeps your transmission locked in the current gear so it won't upshift when coming down hill. It does not hurt anything to engage it the moment you start your engine (towing or not). I've used mine in the mountains of NC, Tennessee, and KY, even when not towing. But towing is where it really shines.
Now, the opposite is Tow-Haul mode. Tow Haul cause the transmission to shift up to the next highest gear at a higher engine RPM.
Cruise control holds the speed steady.
Now, turn on all 3, and you virtually never have to touch the brake or the accelerator once you reached your desired speed.
Tow-Haul will keep the RPMs up when climbing hills so your truck maintains max power in a lower gear. Exhaust Brake keeps the truck in it's current gear when going down hill so the lower gear is actually keeping you from accelerating. When Cruise Control is flipped on, everything just happens! It's so sweet!
โMay-22-2017 08:24 AM
โMay-22-2017 06:28 AM
โMay-22-2017 06:23 AM
DownTheAvenue wrote:
You spent a ton of money on your truck. Why would you not spend a little time reading your owner's manual? The answer to your question and many others will be found there, all written by the people who know best- the people who designed and built your truck.
โMay-22-2017 05:51 AM
โMay-22-2017 05:45 AM
โMay-22-2017 05:42 AM
azdryheat wrote:
What does your owner's manual say?
For my Duramax, the manual says I don't need the engine brake until I'm towing above 15,000 pounds. You may not even need it with the light-weight trailer you're towing.
When I tow my 19,000 pound trailer, the engine brake is always on. Once you turn it on just drive normally and it'll do what it has to do. Make sure your transmission is in manual when going down a mountain grade. Let your lower gears help keep your speed down. Your wheel brakes are not supposed to do all of the work, or even most of the work. Downshift the tranny and use the engine brake to keep your speed down; your wheel brakes are secondary braking items. Like I said before, your truck may not even know your trailer is back there.
โMay-22-2017 04:33 AM
โMay-21-2017 09:00 PM
โMay-21-2017 08:36 PM
โMay-21-2017 08:21 PM
โMay-21-2017 08:17 PM
