Deb_and_Ed_M's avatar
Deb_and_Ed_M
Oct 18, 2020
Fantastic Fan install - no power :-(
OK - finally got around to removing the old overhead crank-up vent on our pop-up TC. I'm astounded how sticky the old Dicor still was on a 22 yr old camper! MUCH scraping later (and grateful for an aluminum roof), the new Fantastic Fan fit perfectly into the hole. I also discovered Northstar already had 12v wiring in place for a powered fan - bonus!
Unfortunately, when I plugged the camper into 110v, there seems to be no power to the wires in the vent opening. :-( (The overhead lights worked, so I did have proper power)
Ed tossed out some ideas - maybe there's no fuse in place for something that hadn't originally been installed; or the wires aren't hooked to ??? on the other end. I didn't even look at the fuse box - it was dark and my back ached and I was getting crabby. Getting old ain't for sissies.
Tomorrow, I will contact Northstar and ask for advice, but I thought I'd throw my question out on this forum in case someone else knows the answer and I can start screwing down the fan.
Thanks for any suggestions!
Deb
