- Iraqvet05Explorer
- pianotunaNomad III
- korbeExplorerI will take a few trips to the spigot with my 6-gal green container with spout (from Walmart) where the spout fits into the fill hole.
- Campfire_TimeExplorerGet one of these from a rummage sale. Use bungee cords to strap down one of these. And mount one of these to a board, and get it hooked up to some plastic water hoses. Make a 12 volt connection somewhere on your trailer that you can hook up the pump with alligator clips to run it. Mount an on/off switch to the board and your good to go.
My dad did this years ago and never has to lift anything. Easy peasy. - 2oldmanExplorer IIYou can lift containers, but it's unlikely you'll be getting 50 gallons that way.
- SoundGuyExplorer
Carry a set of fresh water containers of your choice in the back of your TV for collecting water and you won't have to lift anything. Back at the trailer use a 12 vdc pump, again of your choice, to pump that water from the containers into your trailer's FW holding tank via the FW gravity fill.
Fresh Water Transfer (7 pics)
Collecting water one container at a time using a wheeled luggage cart as suggested earlier works but trust me, having to make repeat trips to the campground water supply gets old really quickly. - Jim_HillExplorerThanks for the tips. I'll purchase linky2 and Water thief.
Jim - Jim_HillExplorerJust noticed the other two posts. More good ideas.
Jim - 2oldmanExplorer II
Jim Hill wrote:
Interesting. I use the water thief so I can use a hose to fill. Not sure what you have against using a hose.
Thanks for the tips. I'll purchase linky2 and Water thief. - scbwrExplorer IIAnother option....portable water tank, a pond pump, and vinyl tubing. I have a 5 gallon water container that I fill with water, submerge a small pond pump to the bottom of the container and use vinyl tubing to pump water via the fresh water inlet. Pond pumps are cheap, and I just leave the pond pump and tubing stored in the water container.
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 13, 2025
