Raife
Jul 21, 2020Explorer
First time tower - multiple questions
Good afternoon. I have read many posts regarding towing and am looking for some additional help. Sorry for the dissertation…
First – context:
Vehicle and weights:
- 2015 Durango, Citadel, V8 Hemi, factory installed tow package, technology group (not sure this matters)
- Curb Weight – 5770 pounds (measured on certified scales, full tank, minus my weight)
- Family weight – 610 pounds (me, wife, 3 kids, and dog)
“Remaining“ cargo weight – GVWR of 7,100 minus 5770 curb weight minus 610 family equals 720 pounds (which I imagine most will be taken up by tongue weight)
Trips – I am planning for 2 trips:
- Trial trip in prep for 2nd trip: long weekend locally (250 miles away here in central Texas) in the next couple of weeks
- Long trip over 2.5 weeks: drive from home to Albuquerque and pick up trailer there. Then poke through midwest/west attractions (Petrified Forest, Grand Canyon, onto California for quick visit with in-laws, then back through Zion, Bryce, Four Corners, drop off trailer in Albuquerque, and drive home)
So in looking through Outdoorsey and corresponding with several owners (i.e. asking for the trailers Gross Vehicle Weight Rating and Tongue Weight) I am norming around low-20 footers to rent.
However, I still have several questions:
1) Electronic brake controller: I understand I should use an electronic brake controller – the Tekonsha P3 showed up today and I plan on installing it this coming weekend (I have installed my hardwired dash/rear cam and I have watched the videos on installing the brake controller to the plug on the D, so I am comfortable doing it myself).
- Given I will be towing infrequently where should I mount it? I was thinking instead of using the screws or bracket, I might use some industrial Velcro and stick it in front of my right knee or on top of the dash to the left of the instrument hood. Has anyone done this? How did it work out? I would be working against central Texas summer heat in the car.
2) Tow weight: I have not gotten a good sense of how much I should/could actually tow. I have had some people say, 7,200 pounds is the tow limit so you can go to 7,200 pounds. I also read about an 80% guideline, etc.
- If I take the Gross Combined Weight Rating (GCWR) of 13,100 pounds and subtract out the curb weight of the Durango (5770lbs), the family weight (610lbs), and the tongue weight (max 720lbs for calculation sake), I end up at 6,000 remaining pounds. To me (if I understand everything correctly) that would be the max Gross Trailer Weight (GTW) I can pull. I would assume it is better to stay under this. This assumes all our cargo (clothes, food, camp chairs, bikes, etc.) goes in the trailer since once I factor in the tongue weight, I don’t have any remaining cargo weight in the Durango.
3) Weight distributing hitch: I read several articles and several of the owners referenced a weight distributing hitch (the manual referenced this as mandatory for anything over 5,000 pounds). One owner alluded to the WDH as a way to go above the 720 pound tongue weight limit. That doesn’t seem right to me. I would assume the WDH provides greater safety and control, not a means to exceed the rated tongue weight.
4) Sway bars: I understand these can be integrated into the WDH, but do I need specific ones based on the trailer weight?
5) Tow mirrors: I am assuming the stock side mirrors are not going to be “out” far enough. I have read several posts that reference most add-on mirrors are junk (my words and maybe some of the poster’s words as well). What is a good option?
6) Trailer weight: I have asked all the owners of trailers I am considering the GVWR for their trailer. Most initially give a rough number or the dry weight. I then generally clarify that I want the actual GVWR and what is printed on the sticker. Is this the right number to ask for? I figure this would be the max the trailer would ever weigh.
Any help is greatly appreciated. I think I covered my questions for now.
Thank you in advance!
First – context:
