Fishhunter
Jan 31, 2021Explorer
Flat
Prolly a dumb question but...do you lift the weight of the camper off the truck before jacking the truck up...never had a flat in all my travels and was just wondering
Grit dog wrote:
This is like a bad joke.
“How many rv.net members does it take to change a flat tire?”
Answer: None of them. They’ll never stop arguing long enough to actually change the tire!
jaycocreek wrote:
Safe Jack for RV'S
BENEFITS
Increases safety
Makes jacking easy in a variety of ways
More stable, and secure
Extends the range and usefulness of the jack
Compact easy to carry and stow
Easy to use
FEATURES
Lift range of 9.5" – 25"
Designed for RV's 24,000 - 48,000 GVW.
Extension Screw Collar provides max useful stroke
Extensions and jack pads can be combined in any combination
Lift at an axle, frame or other lift point
Durable steel construction
Additional extensions can be added to increase lift range
Extensions and pads are always made in the USA
Grit dog wrote:
I'm now not sure if you're for or against lifting from the axle.....and I suspect you aren't either!
jaycocreek wrote:
Safe Jack for RV'S
BENEFITS
Increases safety
Easy to use
FEATURES
Kayteg1 wrote:
It is dog chasing its tail only becouse we like to troll here.
Here is picture from my truck manual.
It is generic picture, not showing details, but clearly shows jack under suspension bracket.
The note saysmanual wrote:
Rear
Note: Jack at the specified locations to avoid damage to the vehicle
Any more questions?
manual wrote:
Rear
