MadFinnHockey
May 04, 2015Explorer
floating flooring questions
I'm considering replacing my vinyl flooring with something like the Allure floating floor. My question is, if you've done it before, did you removed the table tube supports screwed to the floor, then floor over where they were installed then reinstall them, or did you do the flooring around the supports?
Thanks
Thanks
