Flojet Macerator Pump
Redterpos3
My birthday present just arrived, the flojet macerator pump from camping world.:W I couldn't tell when I purchased how far it could pump, but someone said 100 feet (they may not have been talking about this one?), the directions say 50 foot with a 3/4" diameter hose. I'm going to be pumping from my driveway down a slight slope to my sewer cleanout, probably around 100 feet away. Is this a problem? Or will the downslope help everything "move"?
The Travelin' Terrapins!
2016 Ford F-350 SRW;CC;4x4;172WB;6.7PSD;34,000m
2011 Nash 27T 12,995m
2013 Yr1 30nts 3150m
2014 Yr2 52nts 3365m
2015 yr3 25nts 2260m
2016 yr4 46nts 2500m
2017 yr5 24nts 1720m
2018 yr6 4nts 30m
28 REPLIES 28
Redterpos3
I've been reading on the camping world site, and some there say they used jumper cables from the TT battery to the pump wires. This sounds like the way for me to go for now. Is there anything I need to do in order to use this? the clips for the jumper cables seem too big to get a nice bite on the small pump wires? I'm not all that mechanical/electrical. Thanks for any help!:h
2018 yr6 4nts 30m
beemerphile1
Redterpos3 wrote:
My birthday present just arrived, the flojet macerator pump....
Wow, a poop cannon for a birthday gift, someone must love you! :B Sure beats using buckets.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
westend
Don't forget the fuse on that wire!
'03 F-250 4x4 CC
wmoses
Redterpos3 wrote:
Ok, I've looked at the unit and looks like I need to make a number of connections, and get some k ind of "power source," to connect to. How do I do this? What do others use for this connection?
On my previous TV I ran a wire from the battery to the sewer outlet area and installed a trolling motor plug set at the wire - pump connection. I had to cut the clips of the end of the pump wires to install the male plug. Worked well. I have to do this on the new RV.
Regards,
Wayne
2014 Flagstaff Super Lite 27RLWS Emerald Ed. | Equal-i-zer 1200/12,000 4-point WDH
2010 GMC Sierra 1500 SLE 5.3L 6-speed auto | K&N Filter | Hypertech Max Energy tune | Prodigy P3
_
Redterpos3
Ok, I've looked at the unit and looks like I need to make a number of connections, and get some kind of "power source," to connect to. How do I do this? What do others use for this connection?
2018 yr6 4nts 30m
rockylarson
The pump will shut down to cool if overheated. You also might go thru a couple of fuses until you learn the operation. I always run 30 seconds or so of the gray water first to "wet" the hose, and to be sure there are no surprises at eather end. You can also shut the pump off and back flush if it appears to clog or just open the grey valve for a second or two to back wash a little. I run 1 inch hose a hundred feet up hill about two feet at home but only carry 3/4 inch hose on the road.
Good Luck.
Jan and Rocky
Volunteers for USFWS. 29 refuges with 9300 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
eHoefler
I assembled 215' of 1" PVC pipe to pump off our fifth wheel while we lived in it last winter, worked extremely well!
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
edatlanta
I have a FloJet that I have never used. I bought it three years ago when I was going to host at a state park without sewer hookup, but they told me it was 100' from a bathhouse where I could pump into a sewer access. When I arrived I found that it was actually 205' with about a 3' vertical rise. Not only did I not have enough hose, I could just see me with 200' of hose full of black tank "stuff" when the pump would inform me it could go no further.
I never bought extra hose and have never used the FloJet, but I have it if I ever need it.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
Johnadam
I pump mine with 100' of 3/4" hose. It does OK, but as others have mentioned, there is no substitute for opening that valve and WHOOOSH, letting it quickly drain into a short 3" hose. The pump is too slow to get the solids moving good. I usually have to do about 3 fill-pump cycles to get it reasonable clean. Also, if you are going to dump into a septic tank, you will have to use the green tank chemicals. The blue formaldehyde based chemicals will kill a septic tank in short order.
720Deere
I have been using the same pump for about 6 years now. Initially I had 100' of 3/4" hose which ran about half level and half of it slightly downhill. When I built a storage pad for the camper next to my garage, I buried a 1" HDPE line from the septic tank to right next to the outlet on the camper. That line drops about 2 feet in its 60' run and the pump barely seems to make an effort.
Even when I had 100' of 3/4" I never had any problems with the pump getting hot. I never pumped more than 50 gallons at one time though. Really the duty cycle is more important than how much head the pump has. Unless you were pumping up to an elevation 20' higher than the pump, you should not have any issues at all. If you are worried about it, limit the pump to 3 minutes on with a 5 minute break between cycles. My pump never gets so hot that I can't hold my hand on it and it will definitely take more heat than your hand can stand before you damage the pump. Enjoy your Flojet, it is probably the best purchase I ever made in camping accessories!
2011 Ford F-350 4X4 CC LB SRW 6.7
2013 Keystone Fuzion 315
B&W Companion Hitch
1 wife 2 kids and 1 dog
wmoses
I have 100' of 5/8" house and it has no problem pumping through that distance on level ground to my sewer clean out
Regards,
Wayne
_
Redterpos3
MNRon wrote:
they suggested using a 1" hose. They also commented that the concern would be overheating so I watch to make sure the motor doesn't get too hot (it doesn't pumping through the 1" hose).
Ok, thanks! It does sound like the overheating is the issue, and a larger diameter hose is a good idea. I'll look into that! Being able to dump at home from my current spot would be great!!
2018 yr6 4nts 30m
Old-Biscuit
I use mine to pump 75' with a 2' incline.......use a 25' & 50' 3/4" hose.
Typically pump 100 gallons (black & grey).
MNRon
I also have a 100' run to pump, but it's level not downhill. When I got the flojet a few years ago I talked with their technical services and they suggested using a 1" hose. They also commented that the concern would be overheating so I watch to make sure the motor doesn't get too hot (it doesn't pumping through the 1" hose).
I've gone through a couple instantiations of hose and have ended up with 2 50' 1" hoses I purchased from factoryhosedirect.com
Good luck, you'll love the ability to pump out at home.
Ron
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
