โNov-20-2021 07:55 AM
โMar-27-2022 12:22 PM
Grit dog wrote:pianotuna wrote:
Hi,
I think the 75 is a typo.
Try 55 and see what happens.
What would make you think higher speed combined with lower mileage is a typo?
Sounds proportionally correctโฆ
โMar-27-2022 12:06 PM
Urriellu wrote:
Thank you all very, very much for all the replies.
I just finished a second trip and I made a few changes as suggested:
- I went from 65-75 mph avg to 55mph.
- When going uphill I slowed down to 45 mph.
- I started using premium gas instead of regular.
- I speed up after stopping veeeeeeery slowly.
My consumption has gone up from 7.5-8.5 mpg to around 12 mpg. Way better!
Just using premium instead of regular also helped a lot, when not towing I went from ~18 mpg (using regular) to 21-22 mpg (using premium).
Thanks again!
โMar-26-2022 08:25 AM
โMar-25-2022 03:51 PM
โMar-10-2022 09:31 AM
BackOfThePack wrote:Grit dog wrote:shelbyfv wrote:
Probably we can skip the irrelevant posturing. OP apparently got what he wanted and hasn't been back in over a month.
You must be new to BotPโs posts. Theyโre generally a comprehensive ramble, which to be fair, have some good points, but undoubtedly, if he practices what he preaches, is the guy who is _____ing off everyone around him on the highway while heโs practicing hyper-miling! Lol
Unlike you Iโve a few million miles in managing the traffic to get around me soonest. Started that before you were born.
โMar-09-2022 07:52 AM
BackOfThePack wrote:4x4van wrote:Gdetrailer wrote:Agreed that with the correct trailer brakes, the tow vehice can stop the trailer, even in an emergency stop situation. I'm more interested in an emergency "maneuver", such as swerving to avoid another vehicle or something. In that scenario, the trailer brakes are of little value, and the mismatch in weight between the trailer and the truck becomes a major factor in control (or lack thereof)..4x4van wrote:
I have to laugh at the tow capacity wars that the manufacturers are currently waging with small/midsize trucks. Towing a 6400lb trailer with a small 4000lb truck at 75mph? While it may be able to TOW it, and it may be able to STOP it (with trailer brakes), in an emergency maneuver, the trailer will drive the truck. Hope I'm nowhere near the OP when that happens.
Trailer brakes generally are required items once you go above 2,001 lbs in some states and 3,001 lbs in most all other States. So in reality, yes, a "4,000 lb" truck CAN safely not only tow but STOP.
The trucks brakes handles the weight on the truck up to the rated GVWR and the trailers brakes handles the trailers weight up to the rated GVWR.
So in reality, it CAN be safely done, might not be pretty or fun but still very possible to safely stop during emergency maneuvers.
A lot of folks out there towing even greater of a mismatch, while that doesn't make me feel safe it is the reality we must you will want to control trailer brakes as you finish and try to straighten out. deal with. Eventually with a big and heavy enough trailer even a F450-F550 truck will be much lighter than the trailer..
My personal feeling is I would much rather have a bit beefier tow vehicle to start with which provides a firmer platform (IE stiffer springs, firmer shocks and some added weight to match closer to the trailer's weight). But obviously not many people are willing to step off the 1/2 ton platform because they prefer the softer ride and a perceived lower cost to buy and a couple of MPG better mileage when empty.
You should get out and test that. In an emergency swerve you will want to use trailer brake control to finish the maneuver to help bring trailer back into alignment. How do you think onboard TV electronic trailer anti-sway works?
You want the real deal then get a Hensley or Pro-Pride hitch as once the hitch is locked itโs no longer a hitch but a steering component.
So far as stiffer springs go . . no, itโs the FF/RR weight balance + the percentage on the RR axle with as much suspension compliance as possible on a pickup. Softer is better. Stiffly sprung is likelier to lose the tire contact patch. Weight mismatch doesnโt mean much as itโs maybe 2/10s of a second difference once the LEVER with a trailer at the end of it has gotten the drive axle tires free of traction.
โMar-09-2022 06:40 AM
โMar-09-2022 06:19 AM
โMar-09-2022 06:14 AM
Thanks again!
โMar-07-2022 12:15 PM
Gdetrailer wrote:
Rangers are not exactly a prime choice for towing, they are more designed for good mileage under no loads..
โFeb-26-2022 09:45 AM
โFeb-25-2022 05:55 PM
โFeb-25-2022 02:58 PM
LVJJJ wrote:
When you start worrying about gas mileage you no longer can have any fun RV'ing. Last thing I worry about.
โFeb-25-2022 02:36 PM
