โOct-11-2021 09:26 PM
โOct-15-2021 10:51 AM
โOct-14-2021 06:42 PM
HMS Beagle wrote:
I'm a bit surprised by your measurement of 375A - even momentary - to start a small genset. I wonder if is it an artifact of the sampling rate of the clamp ammeter. A Cummins 5.9L diesel draws only about 300A cranking, motorcycle engines in the 1000 - 1200cc range draw around 150A at stall and 100A cranking. These measured with a 100 KHz amp probe on a 1Ghz recording O'scope. Even if it peaks at 375A for a few milliseconds, that would not heat a thermal fuse enough to blow it.
You might try shutting the fuel off or removing the spark wire from the genset, crank for several seconds and see what the starter really draws. 375A @ 12V = about 6 HP!
CB
Channel 17Redneck Express
โOct-14-2021 06:07 PM
MT BOB wrote:
deltabravo ..which he has.... see original post.
Perhaps you should sharpen up your reading comprehension skills, and your knowledge of Fluke meters.
โOct-14-2021 06:27 AM
โOct-14-2021 06:26 AM
memilanuk wrote:
My mistake... it's a 36, not a 33. And yes, it's a clamp-on ammeter and yes, it does DC current as well as AC.
โOct-13-2021 07:57 PM
โOct-13-2021 05:51 PM
MT BOB wrote:
A Fluke 33 cannot measure DC amps, without using a DC current clamp add on.
memilanuk wrote:
My clamp-on ammeter shows 350-375 amps draw - for about a second or two.
โOct-13-2021 04:49 PM
โOct-13-2021 11:33 AM
โOct-13-2021 08:45 AM
โOct-13-2021 05:49 AM
memilanuk wrote:
It's not really ever mentioned as such, but I think towards the end of the Battleborn video I can see some 'extra' cables that look like the generator start leads coming off the battery terminals.
โOct-12-2021 07:50 AM
deltabravo wrote:
I put my generator B+ back to the B+ terminal with no fuse when I switched to Battleborn batteries
When I installed my inverter and BMV-712, I put the generator B- cable on the load side of the shunt. I show the shunt wiring in this video or this one
โOct-12-2021 05:45 AM
memilanuk wrote:
where do I land the generator starting leads at? On the batteries, un-fused and inside the disconnect & shunt? Or on the bus bar - and fused how, exactly?
memilanuk wrote:
Yes, I realize the goal is to not have to use the genny... but I'll feel better knowing that it's still there if I need it.
โOct-12-2021 05:38 AM
โOct-12-2021 05:21 AM
