Gmc grease fittings
SDM
Have a 2011 GMC 3500 Duramax. Two of the grease fittings are hard to get to, would like to change to 90 degree fittings. Does anyone know the tread size of the fittings.
16 REPLIES 16
wintersun
The first time I greased the fittings on my Duramax truck it was a pain. Then I bought a Lumax 90 degree coupler and a new grease gun and it made it a relative snap.
The new grease gun was a Plews pistol grease gun so I could use one hand to hold the right angle fitting in place and the other hand to pump the grease. Well worth the $25 for the pistol grease gun.
I add grease every 3,000 miles and the truck really needs the grease at this mileage mark. No way could it wait for the oil change to be done.
RCMAN46
Bigfoot affair wrote:
#4 & 8, no zerks on the inner tie rods.
Thank You
Bigfoot_affair
Nomad II
Nomad II
RCMAN46
Sport45 wrote:
Good info, but his 2011 should only have 9 fittings.
Post from LML Duramax Forum
Using benk's pictures which two are missing on the 2011?
Sport45
โ€™19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
BenK
Never had a problem with my flex/rubber hosed grease gun. Yes, a good
one where the tip hangs no TIGHT. Mine won't come off if pulled straight
off...gotta pull at an angle
This application is a good one for Teflon particles or any of the solid
lube additives. Main or key to this is doing it often and never allowing
them to go dry. More so with the weight of a diesel or big block
This link is for GMT800, but it looks like my GMT400 and guessing
GMT900's very similar (corporate parts bin stuff)
There is a 12th, but not a zerk. it's on 4x4's front drive shaft and
requires a rubber nosed or some such attachment and this is where a
solid tube works better than a rubber/flex hose
GM GMT800 Grease Fitting Locations
1 - Drivers side, Upper ball joint
2 - Drivers side, Outer tie-rod end
3 - Drivers side, Lower ball joint
4 - Drivers side, Inner tie-rod end
5 - Drivers side, Pitman arm (at relay rod)
6 - Passengers side, Idler arm (at relay rod)
7 - Passengers side, Upper end of idler arm mount
Close up view of the 90 degree, 6mm, zerk that was replaced on the end of the idler arm, where it connects to the relay rod. With the factory straight zerk, it's next to impossible to get a grease gun fitting on it because of the AC compressor/mount that is above it. If you turn your wheels to the left side you can access the straight zerk.
6 - Passengers side, Idler arm (at relay rod) (Different view. Same as #6 above)
8 - Passengers side, Inner tie-rod end
9 - Passengers side, Lower ball joint
10 - Passengers side, Outer tie-rod end
11 - Passengers side, Upper ball joint
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
jmaotto
The most difficult one is what I call the eleventh fitting. Many people do not know it is there. It on the idler arm high up where it is attached to the frame.
N-Trouble
Even with a flex hose on my grease gun the inner three zerk fittings are tough to get at. 90* fitting makes it much easier...
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
RCMAN46
BenK wrote:
Change out the metal tube to a flex hose
Have NOT had one I could not get at
X2
Buy a quality flex hose that has a quality zerk fitting and it will stay on the zerk while pumping grease. The cheap ones do not grip the zerk very well.
BenK
Bigfoot_affair
Nomad II
Nomad II
It isn't that bad of a job....
N-Trouble
I have a 2012 and yes the inner three grease fitting are a bit tough to get to. I first picked up a set of the 90* zerks but found them to be a pain to point in the direction I wanted and also be snug. You have to shim them with small washers to get them to line up the way you want. I ditched them and picked up a 90* adapter for the grease gun. Problem solved and much simpler.
Majja13
I have what sport45 did. Love the 90 degree adapter on the grease gun
2015 GMC Sierra 2500hd 6.0 w/4:10 rear end
2006 SkyLine Weekender 180
1200/12000 Equal-i-zer WDH
fj12ryder
Like Charles said the best thing to do is take one out, if you can, and shop for a replacement. There are usually 2 types of thread so you can't say for sure until you take the old one out.
Don't forget that there are press-in zerks too, these can be spotted by the fact there's no flats on the zerk, so no way to unscrew them. I wouldn't be surprised to see these as OEM.
Howard and Peggy
"Don't Panic"
