anutami
Nov 22, 2014Explorer III
It may not be a blockage. When you are dumping is your camper slanted at an angle? Keep in mind the gray tank is more toward the front of the camper and the black tank is toward the rear so make sure you are higher in the front so the water will run out. The higher the front of you truck is the faster the water will drain.
Nolan
Nolan
44,029 PostsLatest Activity: Jan 27, 2025
