- Roger_in_VERMONExplorerThanks I'll keep watching for other posts.
- 4X4DodgerExplorer II
Roger in VERMONT wrote:
We have been looking for a lite weight towing trailer for our sons. We like the Gulfstream Vista Cruiser. Any comments good or bad.
I have a Gulfstream Innsbruck from 2004. It works perfectly and has no problems. From what I have seen the build quality is better than many TT's and similar to Jayco. It has an actual truss roof. It hauls great. I cant say about the Vista Cruiser.
As for the company's web site it works fine for my browser. I have also had the opportunity to call the factory directly over a question and they were very helpful.
Hope this helps somewhat. - Mike_UpExplorer
Only two people. Not to worried about room I'm more worried about quality. I like the fact it is all fiberglass roof and sidewalls. Looks like they all have a pretty good amount of carrying capacity.
Aluminum structure also sounds good.
Really, that's what I run from. I consider that build, Disposable. It never ceases to amaze me how many laminated trailers, delaminate.
For build quality, I'd stay with "stick and tin". Fiberglass (Filon) skinned' glued together (laminated) walls sure look pretty until the glue fails and they come apart and are all wavy. - Mike_UpExplorer
BubbaChris wrote:
I do see that many of the models do not have slides, which helps with weight and costs. However if it is for more than 1 person, not being able to walk by each other in the kitchen gets old real fast.
Don't agree, many none slide models are roomy as our 26BH. I usually recommend against slides due to leaking and mechanical issues and the standard small love seat instead of a longer sofa.
With a good floorplan, you'll have generous walking area.
My brother's floorplan is exceptional and better than many superslide floorplans without all the extra weight of the superslide. - Roger_in_VERMONExplorerOnly two people. Not to worried about room I'm more worried about quality. I like the fact it is all fiberglass roof and sidewalls. Looks like they all have a pretty good amount of carrying capacity.
Aluminum structure also sounds good. - BubbaChrisExplorerThe company website has technical issues and typos, so that always gives me pause.
You don't say anything about how many people will be using it or which model(s) you are considering. That information will help.
About Travel Trailer Group
44,027 PostsLatest Activity: Apr 19, 2019
