GVWR Question
knesdad
The truck in my signature has a GVWR rating of 7,700 pounds. The combined axle weight at my last weigh in was 8,100 pounds. Problem? (Trailer weight was 6,340. Combined was 14,440.)
Thanks.
Dave.
Dave & Sue
Kiley & Emily
Izzie (Beagle/Bichon/Mini Poodle)
2012 Ford F150 XLT EB SS CRW 6.5 Max Tow
2012 Dutchmen Kodiak 284BHSL -- Dutchmen Owners
22 REPLIES 22
knesdad
The tires are Michelin LTX M/S2 - LT265/70R18E. Load range is 3,085. I can also adjust the hitch to transfer more weight to the front yet.
Dave & Sue
Kiley & Emily
Hybridhunter
knesdad wrote:
Front: 3500
Rear: 4600
This is with Michelin "E" tires. And yes, the WDH is set up correct. Everything sits nice and level. I will have to check the tongue weight and see where I'm at there. I could probably move some stuff from the front storage to the rear bunks, but nothing extravagant is in the front storage...
Well the number that really jumps out at me is that rear axle being over by 550lbs. However that axle itself is rated for 4800, so perhaps it is okay. The spring pack is rated for 4050lbs, who knows what parameters that encompasses other than ride height vs weight.
I believe your truck has the "thicker" frame that is part of the HD package, so no worries there.
As for the WDH, I would try redistributing some more of that weight to the front axle, perhaps with more hitch head angle, or pull up another link on the chain-bars. (Although I don't like that approach). Some will say that's the wrong approach, my thinking is that if overloaded, do what it takes to balance it as well as possible. IMHO, you are over the rating of the 6 lug wheels, and the only difference I can see between the HD pac, and yours, is spring packs, wheels, and shocks.
Your front axle is rated for 4050 lbs. If you have the adjustment in the WDH,IN THEORY, I would shift 350lbs forward, and that should send about 100-150lbs back to the trailer axles. Youd then be under the ratings at both ends.
wintersun
Not necessarily. The axle and wheel bearings can easily take the load. It is the tires that largely determine the load capacity of a pickup. If the weight on the rear axle with the trailer attached is 5000 lbs and the tires are rated at 3200 lbs. each or 6400 lbs. total you are OK. If your rear axle load exceeds the load capacity of your tires I would suggest changing the tires.
If the truck sags in the rear with the trailer load then you can add helper springs at the rear axle or go with air bags.
What people don't seem to be able to comprehend is that the load ratings are based on the weakest link of the truck as it was configured when it left the factory. I have never seen a truck on a dealer's lot that was optimized for maximum load capacity. Easier and cheaper for the factory to add two more tires and make a dually.
With all the 3/4 and 1-ton trucks the minimum load rating for any of the rear axles and wheel bearings used is 8,900 lbs. and most are rated at 10,900 lbs. and this is not the weak link as with 1/2 ton trucks.
JIMNLIN
400 lbs over a GVWR isn't that big of a deal. However a single gross scale weight doesn't tell the owner the most critical things such as being over the trucks GAWRs and in particular the trucks rawr/and those P tire load ratings.
The 7700 GVWR package has a 4050 rawr and probably P tires. As Rick says those P tire's load rating is reduced by dividing it by 1.10 or roughly 10 percent reduction per fed regs.
I would get a reweigh with separate front and rear axle weights. That way you know what is over and what is under. You sure don't want to over load those thin sidewall P tires.
knesdad
Hybridhunter wrote:
What are the axle weights? As another poster mentioned, the HD option ups the rear GAWR. But that's with beefier leafs, and a beefier frame.
Also, is your WDH set properly?
Front: 3500
Rear: 4600
Dave & Sue
Kiley & Emily
Hybridhunter
Vulcaneer
gmcsmoke wrote:
YOU'RE GOING TO KILL SOMEBODY.
according to rv.net
RUN FOR YOUR LIVES
'12 F350 SB, CC, SRW, 6.7 PSD, 3.55 RAR, 6 spd auto
2015 DRV 38RSS 'Traditions'
Pullrite Super Glide 18K
Retirement = It's all poops and giggles....UNTIL someone Giggles and Poops.
whsk
if you are happy I am happy-I have 5435 payload and quit worrying about "STUFF" in the truck!-whsk
RWDIII
Did you get front and rear axle weight?
what was what rear axle ?
Ford rates the 9.75 axle 3850 and 4250 depending on springs
Sterling rates it about 4600.
Add some LT tires and timbrens or work rites
OLD 2006 F150 4wd 7200gvw,Lt275-65-18,Scan Guage,Garmin,flowmaster,load levelers,Firestone work rites Bronco 800
NEW 2015 F250 Scab 4wd 10000 gvw, 6.2 Scan guage,Garmin,work rites,3200 lb load,1800lb Palomino Backpack SS1200
Norskeman
Looks like a F250 would be a better truck to be towing with. Don't think you are looking to purchase a newer truck.
I would tow with all tanks empty and fill the water tank when you get to your destination if needed. Dump all tanks before you leave the campground.
I was in a similar situation with a 2005 Silverado 3500HD SRW with a diesel. Was towing at least 900 to 1000 lbs over the GVWR. I traded the truck for a 2011 when the trucks were beefed up and I am now towing within the GVWR of the truck and worry less.
2017 Keystone Avalanche 320RS
TV - 2011 Chevy Silverado 3500HD LTZ CCLB Duramax SRW 4X4
boogie_4wheel
It's ok, you've got the 6.5L engine. They've always been underrated :B
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer,Transgo Shift Kit ISSPro Oil and LP pressure gauges, GDP 20/2 filters, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
gmcsmoke
according to rv.net
EcoBullet
knesdad wrote:
I did have extra stuff in the bed that more than likely brought the weight up. Just wanted to make sure I was reading the numbers right...
Sounds like you're reading it right to me. I'd get at least 400 lbs of extra stuff out of the bed.
Me 1954, Nana 1954, Grandson 2003, Granddaughters 2005 & 2008
2014 Keystone Bullet Premier 22RBPR
2013 F-150 XLT Supercrew 4X4 Ecoboost Max Tow
goducks10
I guaranty you're over the RAWR if you're over the GVWR. F150's aren't like 3/4-1 tons in that F150's front and rear axles aren't rated higher than the trucks GVWR. You have a RAWR of 4000-4050lbs. Anytime you go over the trucks CCC, 99% of the time you go over the RAWR. BTDT with a 10 F150. Maxed out the trucks GVWR and CCC and was 50 lbs under the RAWR. And that was with an 1857lb CCC. I didn't like running maxed out on all ratings so I moved up to a 3/4 ton.
