towpro
Oct 30, 2017Explorer
I see your pictures. I would try to remove as much of the old caulk as you can, but be careful not to damage the rubber roof, than calk over it joint with Dicore.
Dicore makes self leveling and not self leveling. you don't want self leveling for the sides as it will try to run on you.
while your at it, check the rest of the roof. Look at anything already sealed for cracks in the caulk. you want the self leveling on the roof.
for best repair, clean the roof so stuff sticks better. Maybe blow any water out of that open joint if you have an air hose before sealing it.
44,029 PostsLatest Activity: Jan 19, 2025
