Happijack turnbuckles on Torquelift frame mount
mattyj
Man this equipment adds up quickly, trying to save some money toward our vacation while setting up our new to me 2006 F350 (getting soon) for truck camper. Does anybody used that combination? I used to have Happijack setup on my old truck but I will feel more secure with a frame mount as opposed to a bumber mount system. Thank you, Lou
2006 Ford F 350, 6.0 PSD 8 Foot Bed 4x4 with Torklift Tie downs ,Stable Loads ,rear Helwig Swaybar,airlifts 5000 , Method 305 HD rims . 2019 Adventurer 89 RBS, slideout, Generator
11 REPLIES 11
dakonthemountai
Though Fast Guns are in the future, currently I have the frame mounts and long enough rods on the turnbuckles that chains are not needed.
Dak
2018 GMC Denali "Extreme" and 23' EVO 2050T Travel Trailer
Escapee member #224325-Since 1992
SoCalDesertRid1
Happijac sells the extra long threaded rod hook ends, if you have a short set and want to make them into a long set. Chain also works just fine for extending the length.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
delosholly
Ditto using chains. We use the happijack/torklift combo and use chains on the front with zero issues.
Del
Delos & Holly
2013 Camplite Truck Camper 10.0
2014 Ram 2500 Reg SRW LB
2012 Burgman 650
mattyj
tattoobob wrote:
I got 1/2" threaded rod couplings and 1/2" threaded rod and made mine longer to reach, You can also use chain to make up the difference
. yes that's what I'll do Thanks
tattoobob
2005 Ford F350 SRW 4x4
2000 Lance 1010
mattyj
Does anybody think it would make a difference if I attached a small happijack turnbuckle with a long one to make up the length difference on the torklift tie down?
mattyj
I guess I'll need to buy 2 because the front happijacks are real short , but that's great news thanks evèryone
SoCalDesertRid1
As long as the length is right, it doesn't matter what brand name is used with what. I use Happijac turnbuckles with frame tie downs I fabricated that are somewhat similar to Torklifts. They work fine.
98Ranger 96Tacoma
20' BigTex flatbed
Joe417
I did it for several years on a previous TC. Works great, just used 4 pieces of chain and some screw links.
Joe and Evelyn
Farmerjon
We have Happijack turnbuckles and torklift frame mounts. Worked fine on our 2000 F350.
We have purchased Torklift derringers for our 2015 F350 because of the larger fuel door and convenience of disconnecting for fuelling. Sad to say we haven't been able to use our camper on the new truck yet, so can't say how well they work yet.
2015 F350 Lariat CC LB 4x4 DRW 6.7, 6sp auto, 3.73
2000 F350 lariat SC LB 4x4 DRW 7.3, 6sp manual 3.73
1987 F250 Lariat SC/LB 4x4 SRW 460 4sp stick 4.10
1995 Jeep wrangler
99 Star Craft 953
deltabravo
SHouldn't be a problem running any brand of turnbuckle style tiedowns on the TORKLIFT frame mounts.
