finsruskw wrote:
Towpro,
I am leaning towards the HW at present
Could you expand on the rear frame mounts, different location" a little.
Some pictures would be greatly appreciated.
You could PM me for my e-mail address if you wish.
Any installation instructions you could share w/me?
Thanks!
Dave S
Every model/year truck is different, mine is a 2015 Ram 3500 Diesel 4x4 dually. For my truck there is 2 different models, I went with the larger "bigwig" one.
I was adjusting the location of the rear frame mount plates as they can move forward or backwards some. The nuts are those locking nuts so it can be a PITA to hold the mount, hold the wrench, and turn the socket (I did use an impact gun some). first they were installed to far forward so I moved them back to get the vertical links that connect from the frame plate to sway bar so they were perpendicular to the frame.
Also the bigwig kit came with a bunch of stuff to mount on the axle to move some brake lines. it looks like in 14 this brake mount stuff was attached to a vent on the axle tube, but on the 2015 this mount moved to on top of the pumpkin so I did not have mess with this part.
All I had to do was unclip the brake line on both sides of the pumpkin so the center U bolts would not crush them, then bend them just enough so they would not rub on the Ubolts.
on mine I had to remove (un-clip) 2 electrical connectors (one each side) from the side of the rear frame (connectors for rear fender clearance lights). this same wire going to the connector is also attached to the top of the frame with a nylon plug that goes into a hole in the frame, but I did not have to remove that part (I think plate is slid back until it was hitting this wire attachment point.
all and all it was not a hard job.
Some of the directions might be on line at hellwig's site.
When you order this stuff 99% of the orders go back to hellwig who bents them to fill each order, so expect a coupe extra days delivery.
I got mine from a place called SD Truck Springs. They had free shipping and a coupon for $35.00 off. they got my order on Monday AM, I received my bar 10 days later in UPS.
EDIT: I did mine on the ground, with truck wheels sitting on ground. You want suspension loaded with truck weigh twhen installing it. On the vertical links between the frame and sway bar I have the lower lock nut on just enough to cover the end of the threads with none sticking out. the bar is angled down just a little in the back. Now after I load the camper and truck body drops, the bar should become level. (hellwig said to look for a 10deg angle (back down) with truck empty so it will become more level when truck body drops with camper weight.)
