Freep
May 17, 2020Explorer
Help: DC Power cuts out under load
2014 Lance 992. Symptom is power interruption with moderate to heavy DC loads.
During our last trip we started experiencing brief power interruptions when running loads like heater plus charging laptops and radio running, water pump running. This problem happens at all states of charge for the battery. It never happens when there is AC power available. I suspected the Progressive Dynamics mighty mini and contacted them. I was told it's likely not their power center and was told to look for an inline auto resetting circuit breaker. This I have not been able to locate. I was also told that it could be a bad or loose ground wire.
What I have done:
After this problem presented itself I upgraded the solar on the camper and with my MPPT controller I can see that the battery is still working fine during the power outage. The MPPT controller is wired directly to the battery and doesn't experience a power drop.
I've inspected every wire and connection I can find and still can't find the culprit.
Suggestions are welcome.
What I have done:
- cleaned battery terminals
- cleaned chassis grounding bar
- pulled all fuses and run the fridge on DC ... still happens
- inspected all wires and connections
