timc1207's avatar
timc1207
Help sudden electrical problem - Slides won't work
Got home today from a trip, when I backed into the spot I keep the trailer in the pigtail got caught in between the hitch and the receiver cutting the cord.
Everything still works in the trailer with the exception of the slides. This sounds like a fuse issue but I could not find anything bad in the converter. Anyone got ideas?
  • Found the circuit breakers just inside the frame under the front of the trailer. I'll check them tomorrow.
    Thanks for the help guys.
  • Slides are wired directly o battery with their own fuse/relay.
    Fuse could be blown
    OR if it has a relay (dc circuit breaker---small box with two studs where wires bolt on) it may have a small reset button/tab on side
  • some where under the slide there is another fuse, look where the tongue meets the frame. check out the forest river forum as they will know the exact location
