Blueboat's avatar
Blueboat
Help with Battery Terminal corrosion and why
Maybe some one could help, my battery cables corroded and broke off the battery clamps on my Jeep, lots of green corrosion around the cable clamps (terminals) and cables. 2 things 1 I installed a wench on the front of my jeep and hooked the cables to the end of the bolts that go through the clamps that go around the battery posts. 2 nd I tow my Jeep behind my dodge pick up with the camper on and the jeep steering column will only unlock the steering wheel if the ignition is in the run position so I can tow the Jeep.
