Apr-06-2016 03:37 PM
Apr-10-2016 06:00 AM
Apr-09-2016 10:28 PM
Apr-09-2016 11:29 AM
Apr-09-2016 10:32 AM
Bedlam wrote:Phil Hendrix wrote:
Honestly if I had even the slightest intentions of towing any significant weight at all, it would be a no-brainer decision for me ...I would get the superhitch and not look back. But seeing that I don't even know if I will muster the guts to tow anything behind the already very large and heavy TC I will wait on spending the money for a hitch I might not use.
There are light duty less expensive options available for you if you don't plan to change how much you will tow. If you do end up upgrading to the SuperHitch later, your replacement cost will be for the receiver, rear tie downs and extension. It is overkill for your current application, but it opens up more possibilities later without having to buy equipment again.
Apr-09-2016 08:40 AM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
Apr-09-2016 08:33 AM
Apr-09-2016 05:45 AM
Apr-09-2016 04:34 AM
Apr-08-2016 09:29 PM
Apr-08-2016 08:14 PM
Toad: 91 Zuke
Apr-08-2016 04:47 PM
Reddog1 wrote:Oldtymeflyr wrote:
Curt makes a 2.5" receiver hitch rated at 18,000#.
Here is a link that provides load capacities of different hitches.
Etrailer
I don't know what you have in mind for future Towing Capacity. For your truck there are some hitches with 2400 Pound Tongue Weight and 16000 Pound Towing capacities with a 2 Inch Hitch Opening for about $175.
They also list a TorqueLift with a Towing Capacity of 1700 Pound Tongue Weight and 17000 Pound Towing with a 2 Inch Hitch Opening for about $600.
It may be worth while to give Etrailer a call to discuss what you have and what you want to accomplish. They sell several brands of hitches, with no obvious reason to promote one over the other.
Wayne
Apr-08-2016 03:01 PM
Apr-08-2016 01:26 PM
Apr-08-2016 11:51 AM
Toad: 91 Zuke
