wayfun's avatar
wayfun
Holding in lower gear vs letting tow-haul mode shift
I tow with a 6 speed, 6.2L Tahoe. I usually tow around 55 to 60 mph. With the transmission in tow mode it is locked out of 6th gear and it generally stays in 4th and 5th gears on the highway. At 58 mph I'm at 2500 rpm in 4th and 2100 in 5th. However at a slight grade in 5th it shifts to 4th. If I hold it in 4th the truck just pulls. With the cruise set at 58 I can come to a significant grade and the truck just pulls on without shifting. My question is which mode would be easier on the transmission and torque converter? Intuitively I feel less shifting would be better but I've been told that allowing it to shift would make the transmission run cooler. What's the consensus here?
Dennis
