Faribo
Jul 30, 2013Explorer
Holy Creaking and Popping Batman!
So a little background here.....I purchased a TT with a Reese dual cam weight distribution/sway control system with the round bars. The dealer installed everything and all the wheel well measurements came out perfect so I thought "all is good"....well jump ahead 3 months and I noticed now that the WDH spring bars have absolutely no tension on them no matter what link I use. I start to investigate and find out that the dealer never installed the large locking washers to keep the head from tilting!!! I could probably fix this myself (after I chewed out the dealer and made them send me the parts) however since this is my first TT I wanted to make sure it was done correctly so I made an appt at a very reputable dealer here locally and had them fix the problem.
Now to my issue....when the hitch was first installed it didn't have any of the popping and creaking I've heard about but now after it was installed correctly it is creaking and popping like mad. I do not have the spring bars greased in the hitch head (will be doing that tomorrow) but is this much creaking and popping normal? I get quite the looks as I drive around the block. :) My spring bars are level with the trailer and I am using the 5th link on the chains.
Would love your thoughts and let me know if more info is needed to give some advice. :) Thanks!
