al7601
Oct 28, 2016Explorer
how important is this step in winterizing?
my buddy, who's not good with computers, forgot this step when winterizing last week in NJ. He did not blow the lines and added antifreeze at the water pump bypass inside.
Everything else was done perfect except the below. Will he be ok?
*Remove the small screen over the inlet and push in on the valve with a small screwdriver until you see antifreeze. Replace the screen
