- JBarcaNomad II
BarneyS wrote:
A lot of people loved his posts and no matter if they loved them or not, he never got upset or posted snarky or flaming posts back. Some took offense at his great knowledge and expertise but Ron would answer their flaming posts in a calm, thorough manner and usually shut the flamer down.
He was a huge asset to our forums and his passing was a great loss to many many people. I feel very fortunate to have known him and be able to call him my friend.
Barney
X2 Barney, Ron & I often connected offline on some WD hitch topic, and he would analyze my raw data to help come to a conclusion.
He is missed. - BarneySExplorer IIIA lot of people loved his posts and no matter if they loved them or not, he never got upset or posted snarky or flaming posts back. Some took offense at his great knowledge and expertise but Ron would answer their flaming posts in a calm, thorough manner and usually shut the flamer down.
Barney - TurnThePageExplorer
BarneyS wrote:
Ron's posts were almost intimidating! I loved 'em. I didn't know he passed. :(
See this thread - at least the first post by my friend Ron Gratz (may he rest in peace).
Barney - BackOfThePackExplorer
- BackOfThePackExplorerWeights are placeholders. Static.
Road forces are dynamic. Ever-changing. (Why TW & Payload mean next to nothing: it’s Axle ratings with tire/wheel ratings).
Acquiring the static numbers fits formula for what happens on-road.
Over time these may change. Normal wear & tear OR something’s truly off (defect or damage).
Having a numerical baseline acquired via scale readings shows:
1). The RANGE of adjustments for a given combination vehicle (from nearly empty and on up).
2). Side-to-side and across tandem axle tires the possibility of weight shift.
To TEST is what matters. Braking & steering are what matter in towing. The stupids think it’s about how fast they can ascend a grade (not lose speed). ONLY the downgrade matters, as that’s where most loss-of-control accidents occur from natural or man-made winds.
HANDLING is as much getting a grip on what it should be while solo (tire pressure and bed load securement) THEN some knowledge of what the combined rig feels like.
A combined rig is stable ONLY when under light to heavy throttle. Snapping a trailer back into compliance means BEST braking of both vehicles, and a distance from others full throttle plus MAXIMUM trailer braking is undertaken.
Replication of solo handling via WDH is to AVOID over-correction at the wheel (the pinpointed cause of loss-of-control). “Normal”.
The better the rig tracks (camber changes, ruts, and other surface deviations) the better the outcomes of direction changes not initiated by the driver.
The driver is the weak link. In a straight axle, high COG TV, he’s worsened his chsnces of trailer recovery as feedback from the rig is poor. (A couple of seconds and it’s over). If the trailer can shift the grip of the rear axle tires, Mario Andretti couldn’t save it.
Weigh #2 is to get an accurate read on TW. (Weight shift is bar tension as well as ball angle).
A pickup with a near-empty bed (in terms of weight) is a poor TV. It’s E-Z to lose rear traction in that scenario given road surface problems. And, where cars may slide or spin on losing rear traction, pickups will roll.
High COG trailers (slide-outs) on leaf spring axles are much the same. The design of each vehicle is fundamental as predictor (“skill” claims’ll get you laughed out of the room).
WDH spreads the forces each vehicle is creating across the length represented by the axle trio. Not just at the ball. Makes problems less so.
. - JRscoobyExplorer II
goducks10 wrote:
I still don't understand the need to weigh the front end using a WDH vs just measuring. Most manufactures tell you to return the front of the vehicle to a % of the OEM ride height. If that has been achieved then why weigh it?
No RVer should every weigh their rig. Once they do they can no longer run the highways with no idea how much over the ratings they are. /sarcasm
If MT weight plus tongue weight plus what you load in TV exceeds GVWR of the vehicle, even if you crank the bars tight enough to get the front end ride height same as before hooked up you have no idea how overloaded you are until you weigh. - Grit_dogNavigator
Because to the uninformed, yet cautious driver/RVer this is good information. And it actually is, for training/experience purposes. Not everyone can “visualize” a load with any sort of accuracy.
At one point in my life I had no idea how to tow a trailer or what the potential issues were. For those at that stage of towing knowledge it is good visual proof of how the static weight distribution of everything happens when a trailer is hooked up. - goducks10ExplorerI still don't understand the need to weigh the front end using a WDH vs just measuring. Most manufactures tell you to return the front of the vehicle to a % of the OEM ride height. If that has been achieved then why weigh it?
- BarneySExplorer IIISee this thread - at least the first post by my friend Ron Gratz (may he rest in peace).
Barney - JRscoobyExplorer II
valhalla360 wrote:
JRscooby wrote:
Can you explain how the "squat without taking weight off"?
Look at a lever on fulcrum. Add weight to 1 end, weight comes off the other end. The fact the fulcrum moves (rear suspension compression) does not change that.
With simple ball hitch, yes, the frame will act as a simply supported beam and yes, it will take some weight off the front axle if you put any weight on the hitch. Of course, with the really long wheelbase trucks (4 door long bed), it takes negligible weight off the front axle while all the hitch weight, all the in bed cargo weight and any weight off the front axle...goes onto the rear axle. So if you take 150lb off the front axle, you might be adding 1500lb to the rear axle when you are fully loaded. The result is...it will be hard to accurately measure any rise in the front axle while the rear axle is likely doing to drop by at least a couple inches (depends on the truck model...1/2 tons will be more duallys less)
But with a WDH, the trucks frame no longer acts as a simply supported beam, so you can't consider it a simply supported beam.
So you agree adding weight anyplace behind rear axle will reduce weight on front axle. And I bet somebody that paid attention in gee, I'ma tree class could tell you how much if given the amount of tongue weight, distance rear axle to ball, and wheelbase. Now like you say, without knowing the front spring rate, and what percentage of the front axle weight is moved no way to predict how much the bumper will lift. But the fact the rear suspension compresses does not change the amount of weight transferred.
As a pro, I never had much to do with WDH. But just another lever. Fulcrum is the ball. Force applied to trailer end, the load is what is trying to counteract movement the weight on rear axle causes in frame.
About Travel Trailer Group
44,029 PostsLatest Activity: Mar 15, 2025
