carringb
Nov 13, 2013Explorer
Lessmore wrote:
I bet the theft detected code is the reason that the engine shut down after 1-2 seconds. Just a guess though...I don't know Fords.
It won't fuel while the theft error is active.
Was the battery connected when the truck arrived? If the cluster was re-connected after the battery was connected, that can cause a PATS error too. Might be worth a shop to disconnect it for an hour to clear the fault (it will come right back if it is a VIN or CAN error.)
44,029 PostsLatest Activity: Jan 13, 2025
