FireGuard's avatar
FireGuard
Oct 10, 2015
Installed my lower stable loads.
I finally got around to getting my stable loads installed on my Ram.
Thanks Buzzcut and others for the good advice.
By placing a floor jack under the front spring mount it created plenty of room between the springs and I only need a little pressure from a prybar and the bolts slid right in the hole.
I ended up using 2 wedges in front and only 1 in the rear. My camper isn't that heavy so this set up should work well. The truck didn't sag that much with stock suspension.
Next will probably be a Reese Titan hitch so I can keep the factory hitch to mount a cargo rack and use a 24" ext in the Reese to tow or carry my dual sport.
