FireGuard
Apr 07, 2016Explorer II
Jack truck up to engage lower Stable Loads?
I installed my lower SLs on my truck last night. Fairly straight forward install, but a couple of pointers that may help.
In order to install the long bolt that secures the plate to the spring you need a pretty good gap between the springs, For the rear, a floor jack under the hitch worked well.
For the front, place the jack under the mount that attaches the spring pack to the frame.
You may need to pry just a bit with a bar but not much.
I used 3 shims front and rear. The front I was able to rotate the shims between the springs without jacking the truck, but the rear had to be lifted.
I noticed in the instructions it recommends to jack the truck up to engage the SLs.
This seems like more of a hassle then a quick operation, but it definatley supports more weight.
Do those running the SLs do the same or should I remove a wedge or 2 in order to engage them without lifting the truck?
With my Lance 981 which weighs over 4K lbs my truck only squatted 3 3/4" and the new Rams sit pretty high. I'm just a hair low in the rear but don't think I'll need airbags.
I haven't driven it yet but it feels pretty solid. I'm still waiting on my Big Wig sway bar.
